Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-05-2011, 02:35 PM
schri00 schri00 is offline
Cylinders order
Hi everyone, I need someone help me confirm the cylinders order in a 1992 Ford Ranger with a 4.0L engine.
According to some information I was given, if you stand in front of the engine, facing the drive belt, the spark plug wires connected to the cylinder head on your left, the one with the oil filler cap, should connect to cylinder numbers 1, 2 and 3, front to back. The spark plug wires on the cylinder head to the right should connect to cylinder numbers 5, 6 and 4, front to back.
Is this order correct: 1, 2, 3 on one side and 5, 6, 4 on the other side?
Thanks a lot for your help.
Old 03-05-2011, 04:29 PM
danielsatur danielsatur is offline
Re: Cylinders order
Firing order 1-4-2-5-3-6
Physical cylinder assignment -
Tran
3 6
2 5
1 4
fan
Old 03-05-2011, 06:11 PM
Re: Cylinders order
Great. Thanks a lot Daniel. I'm glad I double-checked. The cylinder order I had initially did not seem quite right.
The Following User Says Thank You to schri00 For This Useful Post:
danielsatur (03-18-2011)
cylinder order??? 90 montero 24T Eclipse Problem Diagnosis 1 09-17-2005 04:59 PM
Left bank cylinder order WickedNYCowboy Camry/Camry Hybrid/Vista 6 08-20-2005 02:44 AM
2001 5.3L Cylinder Order....MISFIRE problems Myerz Silverado 3 03-02-2005 09:57 PM
Cylinder order danjack Camaro Discussions 3 08-10-2004 03:02 AM
Spark plug order or cylinder order vkhamphi Malibu 2 05-16-2004 09:31 AM
