Old 03-05-2011, 12:08 AM
hammer2 hammer2 is offline
radio very dim, new bulb didn't fix it
2000 SE the radio/clock was very hard to see. had to have sunlight hit it just right. read around here and elsewhere and ended up replacing the backlight with a radio shack bulb. maybe helped a little but still not very good so shelled out $8 for the GM bulb. still not good. the bulb is good, tested it with battery. what else could it be? you can see display if you get right next to it and if lighting is just right.
Old 03-05-2011, 07:46 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: radio very dim, new bulb didn't fix it
the PCB that the bulb plugs into may be bad.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-05-2011, 05:17 PM
doctorhrdware doctorhrdware is offline
IF you can measure the voltage at the pcboard, you should get approximately 12Vdc at the connection for the display lamp. That will also dim with the interrior light dimmer. If the voltage is missing check the wirring going to the radio. There might be a problem with the wire that supplies the voltage for the display back light. Does the bulb light up at all. Also are the rest of the dash lights, on and are they bright?
Old 03-05-2011, 09:44 PM
can't really measure the voltage because to get to the contacts, you have to take face plate off and there are several connectors that get disconnected as faceplate comes off. so unless you want to run jumpers from all these pins and hope that nothing shorts, you can't easily do this. all other lights work and brightness is fine. just the display is dim. I still have the plastic dash off. when it is night, if I trick the sensor into thinking it is daytime, I can see a white light come on through the holes in top of radio. then if I remove the light shining on sensor, after a while the light goes out. I think I am gonna remove the bulb and see what happens to determine if that is the bulb that is lighting up. should the backlight bulb be lit all the time? or only during daytime? let you know of results.
Old 03-07-2011, 12:00 AM
OK I had it wrong. here is what happens
at night if turn radio on I can see a white light through the holes in top and L side of radio. it dims when I dim dash lights. if I then trick the sensor into thinking it is daylight, the light goes out. and when I removed the brand new LCD backlight--nothing changed! so I don't think the backlight is coming on, and the other light I see is the backlighting for buttons on the radio--they wouldn't need backlighting during daytime and that is why they go out when I trick sensor. The LCD WOULD need backlighting during day-actually brighter light during day. it should then dim when it is nighttime, and dim further with the dash dimmer also. at least that is how i remember it working.
so I guess something else wrong (PCB?) not likely worth fixing.
Old 03-08-2011, 01:00 PM
rkvons's Avatar
rkvons rkvons is offline
You should look carefully at how the bulb is mounted. Mine was originally soldered in and had to be un-soldered and then twisted to remove it. You could solder a couple of pieces of wire where your bulb is supposed to hook up and bring them out of the radio. Then install the radio and once it's on, measure the voltage across this new set of wires. Did you verify that your old bulb was burned out? I would make sure the bulb contacts are connected to the PCB contacts.
Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse Baxoid Grand Prix 2 01-03-2010 06:50 PM
New intake manifold gaskets didn't fix it. skwayne74 Caprice 2 06-01-2008 12:31 AM
Service Engine Light - new EGR valve didn't fix it SmlHpy1 Grand AM 3 12-01-2005 09:33 AM
'89 Sable Wagon front lights very dim, new bulbs. Ruffryder2004 Sable 0 01-06-2004 06:27 PM
Very Dim Headlight chillinMax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 06-09-2003 09:31 AM
