Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-31-2008, 04:45 PM
skwayne74 skwayne74 is offline
New intake manifold gaskets didn't fix it.
Hello all, I have a 1991 caprice classic 305 with coolant in the oil system. I have already changed the intake manifold gaskets, gunked the oil system (minus oil pan removal) and changed the oil (2x). I started the vehicle again on friday and there is coolant leaking from the exhaust, and I still have that capuccino looking oil. I have 159,988 mi. on the car, and getting rid of it is NOT an option. Please give me some detailed advice/instructions on what to do next. I am a moderate do-it-yerselfer, so I can do just about anything with proper instruction, thanks in advance.
If YOU got it... A trucker brought it!!! Thank us
Old 05-31-2008, 07:14 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: New intake manifold gaskets didn't fix it.
Well, to get all the "cappucino" out of the oil you have to change it more than twice if it was bad enough. I've seen it contaminated badly enough where it took 6 full oil and filter changes before the oil back 100% back to normal. You have to remember, the contaminated oil is all throughout the engine so each time you put fresh oil in and start it, it get's re-contaminated with the residual "cappucino" in all the engine's parts. As far as the coolant being in the exhaust, are you sure it's not just condensation in the exhaust system?
Old 06-01-2008, 12:31 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
The "cappucino" is coolant which is highly damaging to bearing surfaces. You will need to flush out the engine. What I would do is a 20% diesel 80% oil mixture for one oil change - but DO NOT drive the car like this. Put in this mixture, idle the engine until its warm, then change the oil again using normal oil. Change the filter both times, as well.
Before you do this however, your problem was likely never the intake gaskets to begin with. It sounds more like a problem with a warped/cracked head (and subsequent gasket failure). Get that checked out FIRST before anything else.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
