Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 03-04-2011, 07:22 PM
huey224 huey224 is offline
blower motor and signals not working?
got a 88 lx i just bought and the only thing that wont work is the blower motor and signals i ut a jumper wire on it and it works used a test light and there is no power coming in. i traced the source to a little black box under the dash that all the wires go in and when i put a jumper wire on it started clicking. what is this box? ford part number on it is
E6ZB-8C609-AA
Old 03-06-2011, 09:29 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: blower motor and signals not working?
E6ZB-8C609-AA
Which component did you jumper wire, which component did you use a test light with and which component did you trace the wires from?
Have you checked fuses yet, just to make sure you do not have any blown fuses? These two components run off different fuses and modules, so they should not be inter-related..
Directionals are controlled through the multi-function switch, do your hazards and high beams work?
Does the blower motor work on the high setting at all? Going back to my first question, did you check for voltage at the blower motor connector with the connector unplugged? Or did you check for voltage at the blower motor resistor? If the blower motor resistor went back (which is common) then you will have no voltage to the blower motor connector, expect only in the high position.
Here are a couple diagrams for reference, check the fuses and let me know about the other questions I asked as to where and what exactly you were testing.
-Craig
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 03-06-2011, 10:47 AM
I figured it out it was the cooling fan module/control thats where the wires went when i traced it and it was just clicking i unplugged it and the board was cooked!! it melted all the solder i found new ones but i think im going to take my chances at pullapart. thanks for the help
Old 03-06-2011, 05:29 PM
HiFlow5 0's Avatar
Stanger
You don't seem modules normally just cook, hopefully you don't pop another one when you swap it. Good luck.
-2013 Ford Flex
-1999 Ford F150
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
'01 -- window motor and heater not working Fordina Windstar 2 11-30-2009 10:46 PM
Blower Motor 1-3 not working gravis2000 Grand AM 6 03-30-2007 08:36 PM
1985 Century Blower motor & Speedo not working fordgeek Century 0 01-12-2005 02:31 AM
turning signal not working and display lights out... Brando Calrissian Corolla/Matrix/Voltz 0 06-19-2004 08:24 PM
