Old 03-03-2011, 07:39 PM
dpizzarella dpizzarella is offline
88 Civic Idle Problem
I have a 88' Honda Civic DX 1.5L When I put the new motor in about 3 weeks ago I noticed it had an idle problem when the motor warms up it will go from about 2500 - 3000 RPM to 700 - 1000 RPM. This only happens after the motor is warmed up on cold starts it idles fine no problem. when this problem occured I unpluged the map sensor. the idle problem stopped but the idle was a little high but stayed at that rpm. I got a used Map sensor at the wrecking yard and it helped alot but now its getting worse same thing i unpluged it and it stoped the changing rpm's anyone else have this problem or know what else could be wroung or do i need to get another map sensor??? Thank You
Old 03-03-2011, 09:09 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: 88 Civic Idle Problem
Check all the vacuum lines for leaks. There are several usual culprits for the idle doing that, I just can't think of them at the moment other than vacuum leaks.
Tony
91 Civic Sedan DX - Stock 287k Miles
The Following User Says Thank You to Tony For This Useful Post:
dpizzarella (03-03-2011)
Old 03-06-2011, 10:35 PM
I checked all the lines and replaced the 1 line going to the map sensor. seemed to fix the surging from high to low rpm's but it still seems to idle a little high any ideas? i cleaned the throttle linkage up but nothing any ideas would be great, thanks
Old 03-29-2011, 12:19 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Have you tried adjusting the idle screw? Whats the idle sitting at?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 03-29-2011, 04:43 PM
Tony's Avatar
TLD Member #1
I would adjust the linkage before the idle screw.
Tony
97 stock Civic Idle problem ZCIVIC 4G '96-'00 Civic 3 01-30-2005 06:35 PM
Civic Idle Problem ZCIVIC 4G Let's get Technical! 2 07-15-2004 03:03 PM
civic idle problems jboster Central US 6 03-08-2004 01:45 AM
civic idle problems HELP !!!!!! jboster '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 08-23-2003 12:57 PM
'89 Civic idling problems buddyo5 '71-'87 Civic | CRX 2 01-16-2002 01:55 PM
