Go Back   Automotive Forums Car Chat > Honda > Locations (USA, Canada, Asia, etc...) > Central US
Central US Texas, Michigan, Chicago, Kansas, etc...
Old 08-22-2003, 05:57 PM
jboster jboster is offline
civic idle problems
Can anyone give me any ideas on why my 97 civic will not idle correctly. Idle spped jummps from 800 - 1500 over and over again. THere are no codes adn appear to be no vacum leaks. the car has no modifications
Old 08-25-2003, 12:12 AM
BullShifter's Avatar
double check all vacuum hoses - listen for the HISS while gently flexing each hose. MAP sensor or EACV problem possibly
Old 09-29-2003, 10:40 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
Might try re-setting the idle, by pulling the EACV/IAC connector. It will throw a code tho, just re-set the ECU after your finished.
Make sure there is no trapped air in the cooling system. It will cause the ECT sensor to send bogus signals to the ECU.
Just some thoughts...
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 01-01-2004, 02:28 AM
kingz52 kingz52 is offline
I'm having that same problem with a 97 civic also, EX VTEC engine.
Old 02-17-2004, 03:24 PM
Teggy Pwnage Teggy Pwnage is offline
Send a message via AIM to Teggy Pwnage
Are you sure its not the heating or cooling system kicking in, or turning you wheel(revs for the power steering) or anything like that.
Old 02-17-2004, 06:34 PM
travagliante's Avatar
travagliante travagliante is offline
Re: civic idle problems
Hey i bet he has the problem fixed since this was over 5 months ago!!!!!!!!!!!!!!!!!!!!!!!
Old 03-08-2004, 02:45 AM
QuackerStacker's Avatar
QuackerStacker QuackerStacker is offline
if it is only doing it a little then the car just needs to warm up if not then you may want to see how much fule is being pumped it could be fule line is cloged or some thing like the injectors
~Michael Alexander~
