Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-15-2004, 03:08 PM
ZCIVIC 4G's Avatar
ZCIVIC 4G ZCIVIC 4G is offline
Unhappy 97 stock Civic Idle problem
I have a 97 Civic stock 1.6 non vtec and im having problem with the idle. When the car warms up and when im only in park or nutural, the idle goes up and down in between 500 and 1100 rpm. When i take and plug the IAC (idle air control valve) inlet hole the engine runs fine. Any suggestions on what the problem is. I tested for an intake leak w/ propain also i used intake cleaner it the inlet hole to the iac. I recently got a code for the iac and then i had problem taking off in gear. it sort of studdered. i cleared the code and the studder was gone. Any help will be great. Thanks
Old 01-28-2005, 09:15 AM
j_q_z_a j_q_z_a is offline
Did you manage to sort out your idle problem as i seem to have a similar prob. My car gets warm then the idle jumps from 1000rpm to 2000rpm and back to 1000 again. was it the ICV as i think that is the prob with mine.
Old 01-28-2005, 02:21 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: 97 stock Civic Idle problem
pull off the IACV and look at it. check for tears and clogged screens. replace or clear as neccessary.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-30-2005, 06:35 PM
ZCIVIC 4G's Avatar
Ya i Did. I just remove the IAC and it fixed the problem. Actually i just replaced the whole throttle body.
90, Civic SI ZC DOHC
Stock Adjustable Cam gears
Short Ram Intake
Catback Exhaust
MSD Ignition
Iriderium Plugs
Dual Spring Coil Overs
Tenzo Front and Rear Strut Bars
Wings West Front Air Dam
Hatch's Rule: Faster and light then "Sedan" and more room then the "Rex's"
