Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-03-2011, 04:04 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
ABS brake lights intermittedly comes on.
This is what i got, from a snap-on scanner.
Teves IV Codes
45-LF inlet supply voltage interruption
11-Valve supply Valve circuit
44-RF isolation valve circuit
42-RF oulet valve circuit
41-RE inlet valve circuit
56-LR outlet valve circuit
55- LR inlet valve circuit
52- RR outlet valve circuit
51- RR inlet valve circuit
Old 03-03-2011, 07:52 PM
danielsatur danielsatur is offline
Re: ABS brake lights intermittedly comes on.
Check your front wheel speed sensors.
Old 03-29-2013, 10:39 AM
As you can see, i have been away for awhile. I replaced both sensors on each side, but the ABS brake lights. Still comes on and goes off after awhile, while i am driving.
Old 03-29-2013, 11:20 AM
Tech II Tech II is offline
None of those codes have anything to do with speed sensors.......
This is a real old system......don't even know if parts are available........if you want to diagnose this yourself, you have to know how to read schematics, and get a GM manual for this, otherwise I recommend a GM dealer.....the other alternative, is remove the system and put "base" brakes in.....or live with it....I assume the base brakes work, you just have no ABS function....
Old 04-02-2013, 01:45 PM
In the state of Va, vehicles are inspected once a year, to make sure all safety equipment, are working. If they find the ABS is not working, they can reject that vehicle.
Old 04-02-2013, 04:29 PM
Same here in Massachusetts.......
Old 09-08-2021, 02:14 PM
I was at pick-n-pull during the year 2019, looking for a part for my wiper motor. The Aurora that I got the part from, also had a ABS brake module on it. So I grabbed that too.
After installing the brake module, the ABS brake light works normal. It comes on at start up, then goes off. The traction control button also works now.
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 11:19 AM
1999 Blazer: Service 4wd warning light - intermitantly comes on skyzend Problem Diagnosis 1 10-29-2007 09:33 PM
ABS, Brake Light keep coming on intermittenly on the dashboard panel mrm2681 7 Series 2 08-23-2006 09:08 AM
Abs/brake Light Is Coming On ? ? 1996 Jubahaw Windstar 11 11-01-2004 01:41 PM
Brake light is coming ON on Accord2000 Bobby00 Accord/TSX/Accord Hybrid 4 09-23-2004 10:36 AM
