Go Back   Automotive Forums .com Car Chat > Dodge > Avenger
Old 03-02-2011, 11:45 PM   #1
schwanracing
1998 Avenger 2.0 reman engine
may be a stupid question but i bought a reman engine for my avenger the tag says i must prelube engine before CRANKING engine but no instructions on how to do this. any ideas?
schwanracing is offline   Reply With Quote
Old 03-12-2011, 09:21 PM   #2
schwanracing
Re: 1998 Avenger 2.0 reman engine
to answer my own question the only way i could find to do this was to remove the oil pressure sensor went to lowes and got some rubber hose. a barb fitting to fit in the hole where the sensor was, a drill operated pump and a gallon of oil. i put the fitting in the block where the oil pressure sensor goes hooked up hose to pump then pumped til i seen oil coming out of lifters,and replaced oil pressure sensor then before i installed the spark plugs or valve cover i disabled the fuel system cranked the engine til oil came out of the lifters. seemed to wok fine on my engine but still not sure its the way the reman company wanted.
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 05:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 05:59 AM
1998 Avenger 2.5 whitey01 Avenger 0 01-04-2008 12:35 PM
97' avenger 2.0 liter Head Gasket Reapair Intrigant04 Avenger 7 10-04-2007 10:32 AM
For Sale: 97 Avenger 2.0 EvvyPedderLLK Avenger 0 08-27-2005 04:32 AM
