Old 03-02-2011, 03:02 PM
firecam421 firecam421 is offline
2002 grand am brake problem
2002 pontaic grand am 3.4 liter brake pedal goes to floor i figured i would bleed the brakes in doing so i did the rear passenger then rear driver then front passenger and then front driver. alll bled fine except front driver did it for about an hour still getting air out it would bleed good for a few tries then just a burst of air any ideas would be great
Old 03-02-2011, 03:31 PM
thephantom1492 thephantom1492 is offline
Re: 2002 grand am brake problem
it might sound stupid, but... have you checked for leak? if the hose is broken somewhere it will allow air in, and also oil out. Also check that you have enought brake fluid.
Old 03-02-2011, 03:32 PM
inafogg inafogg is offline
did the brake fluid resivior run dry??if so & there are no leaks you may
need to keep bleeding.you may need to pressure bleed or use a scanner
if we have air trapped in abs motor.
hows the brake pedal feel now?still go to floor?
if car has enough braking you can try driving to force air pocket
then rebleed
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 03-02-2011, 06:14 PM
Thank u but yes i did look for leaks can't see any brake fluid on the lines. I did replace brake hose. a no the resevoir didnt run dry. im gonna try bleeding again cause pedal goes to floor now. there is no brake light on should i still scan it
Old 03-02-2011, 06:27 PM
no,i mentioned the scanner for bleeding brakes.if air gets really trapped
in an area like the pump, the use of a abs compatible scanner will help & may be needed
Good luck
Live For Today
Yesterday is gone,
Old 03-02-2011, 06:34 PM
why was the hose replaced,did it burst??which one L/R??
not sure how you bleed system,but if you can get a gravity
bleed going & let it bleed for awhile,it may work for you
Good luck
Live For Today
Yesterday is gone,
Old 03-02-2011, 11:36 PM
So basically, you lost all braking power and no leak? and didn't ran out of fluid?
if so, stop bleeding, you have a defective something. Master cylinder or ABS...
With the engine off, but key to on, does the brake light turn on, then off? or stay on?
Old 03-03-2011, 08:34 AM
no we did not loose all braking power the car stops just pedal goes to floor on occasion then needs pumped up. an i started bleeding with the rear passenger then rear driver then front passanger and front driver i believe that is the right way if not please let me know. i was thinking master cylinder but when i talked to some mechanics they said it would go to the floor all the time.
Old 03-03-2011, 11:07 AM
still sounds like you have air in system,keep bleeding...w/scanner if possible
Live For Today
Yesterday is gone,
Old 03-03-2011, 02:16 PM
Where am I able to get one of scanners
Old 03-03-2011, 02:41 PM
borrow or buy one. the places that offer free scanning are not ABS compatable
Live For Today
Yesterday is gone,
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
2002 Grand AM problem Mohaavi Grand AM 3 12-17-2009 04:02 PM
2002 LR brake problem tempfixit Century 7 09-28-2009 09:59 AM
2002 Galant Brake problem milo3169 Galant 1 11-30-2005 06:57 AM
2002 Malibu brake problems! shellylynn Malibu 7 05-12-2005 03:01 PM
