Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-01-2011, 02:46 PM
KW4141sac KW4141sac is offline
pop/knock sound rear passenger side by seatbelt
2004 Tahoe
as soon as I turn the key- the pop/clunk /knock sound comes- mostly continuous, comes from the rear passenger side
sound continues when the engine is started- continues when driven- not very loud but is noticeable
any ideas??
Old 03-01-2011, 05:48 PM
777stickman 777stickman is offline
Re: pop/knock sound rear passenger side by seatbelt
Welcome to the forum. It's virtually impossible for us to diagnose noises over cyber space.
My suggestion is to get under it and pin point the source of the noise and post back with your findings.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-01-2011, 06:09 PM
j cAT j cAT is offline
Originally Posted by KW4141sac View Post
2004 Tahoe
any ideas??
if you have the AIR RIDE GM suspension this may be the air compressor. this can be costly to repair . most disable this and install regular shocks if possible .remove fuse for this air pump see if it stops noise. if so go to a repair shop that can bypass this and make a cheaper repair..dealership can cost over a thousand to fix..post back how it is..
the air shocks fail at this age. compressor is most likely shot. not designed for much work load after warr period ends..
Knocking sound coming from rear passenger side wheel lamar9406 Crown Victoria 0 08-24-2009 10:23 AM
2005 CRV - rear knocking/rattle near passenger-side wheel-well area??? Kube CR-V 3 05-05-2007 09:37 PM
2005 Altima, passenger side seatbelt locked amyvision Altima 1 11-13-2005 11:22 AM
Need Help Camaro Makeing knocking sound. from rear passenger side. virus-script Camaro Discussions 7 07-21-2005 11:52 AM
knocking noise from passenger side front tire jeter1955 Grand AM 5 06-15-2004 08:37 AM
Tags
2004 , inside , poping , rear , tahoe
