Old 06-07-2004, 07:01 AM
jeter1955 jeter1955 is offline
knocking noise from passenger side front tire
When i take off in drive you will hear a knock... almost like something is breaking.. it sounds like its right behind the tire... Im not sure what it could be.. if you have any suggestions please help.. i also have a 1995 grand am gt with the 3.1L V6....
Old 06-07-2004, 08:27 AM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Re: knocking noise from passenger side front tire
tie rod or joint , grab that wheel and shake it from the top back and forth till you hear the pop or metal on metal sounds. Shake it real hard so you can find the trouble spot. Also when you push hard on that corner of the car does it get hopping like a boat on a wavy lake?
If its not clean CLEAN IT!!
If its not gleaming SHINER UP!!
If its not appealing BAG IT!!!
Old 06-07-2004, 07:18 PM
michelle77 michelle77 is offline
My grand am made a Knocking noise also and it was the harmonic balancer needed to be replaced...
Old 06-14-2004, 05:43 PM
firstasstchief5 firstasstchief5 is offline
could try the wheelbearing.
Old 06-15-2004, 07:21 AM
MARTIN KORDOS MARTIN KORDOS is offline
it sounds like you have a broken cv boot on the shock check that first (kiss) keep it simple stupid,it most likely will be that.
marty
Old 06-15-2004, 08:37 AM
Re: Re: knocking noise from passenger side front tire
Lets not call people stupid in the forums ok. Especially with a quote.
