Old 02-28-2011, 10:40 AM
slayer5's Avatar
slayer5 slayer5 is offline
water pump replacement
what is the best way to gain access to the water pump ? I have done it on my 94' 3 cylinder, but now my wifes 2000' metro 4 cylinder needs water pump. Its alot tighter in the 2000' and was needing advice like take fender off or something like that .
Old 03-01-2011, 04:02 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Re: water pump replacement
You need to do a Timing Belt replacement plus one or two more steps for the water pump. A lot of the work will be done through the wheelwell, it's necessary on a four cylinder to remove the passenger side motor mount and drop the engine down a couple of inches for good clearance.
http://www.teamswift.net/viewtopic.php?f=2&t=26588
http://geometroforum.com/topic/2232748/
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 03-13-2011, 05:22 PM
slayer5's Avatar
Thumbs up Re: water pump replacement
Yea the passenger side motor mount I removed, and used a floor jack to raise or lower engine. Pump is on and all is fine. Thanks.....
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
Water pump replacement.. and upper brake light/bar/LED replacement vballfun Blazer 4 05-12-2005 08:49 AM
95 blazer water pump replacement? flytem3 Blazer 2 08-29-2003 07:06 AM
Water pump replacement on E30 spikedjax 3 Series 2 07-17-2003 05:54 PM
water pump replacement Steve A Integra 2 06-19-2002 12:02 PM
