Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 02-28-2011, 10:13 AM
jlazyh jlazyh is offline
2000 Neon Fuel problem
I am so glad I found this forum. I need some help (input). I have a 2000 Neon with about 120k miles on it. I is in great condition and runs fine. Here is my problem. It starts and runs fine but after driving for about 20 miles it just runs out of gas and stalls. If I let it set for about 10 min. I guess it cools down and it will start right up again. I bought a new fuel pump unit and understand that the filter and all is built into it. Before I drop the tank and replace it is there a chance it could be something else other than the pump/filter I should be looking at first. Thank you very much for any help and input.
Jess
Old 03-05-2011, 04:33 PM
Re: 2000 Neon Fuel problem
Well I replaced the pump and the pump relay. STILL have the problem.
Has no one here had or herd of this problem?
Old 03-07-2011, 01:08 PM
Just had the Neon checked with the little computer thing. The only thing it showed that was bad was the ignition coil pack. Does that sound to anyone like that could cause the problem?
Old 03-07-2011, 06:06 PM
Damn that wasn't it either. Now it says the Cam Shaft resistance Sensor is bad. Could that be it?
I really don't know why I ask these questions HERE. No one answers. Does it take a long time to get into your click?
Old 03-08-2011, 09:24 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Is your Check Engine Light on? What code did the "little computer thingy" give you?
2003 Dodge SRT-4
Old 03-08-2011, 11:55 AM
I just got back from having the codes read on the car. The only code that shows up is: P1391.That is the Camshaft Position Sensor and the timing belt has either stretched or jumped.
The check engine light has gone out after driving it for a few miles.
Old 03-08-2011, 12:42 PM
Are you still having the stalling problem?
2003 Dodge SRT-4
Old 03-08-2011, 12:46 PM
Yes
Old 03-08-2011, 01:11 PM
Pull the cam sensor clean it up and reinstall and see if you continue to have the problem. If so, you may need to replace it.
2003 Dodge SRT-4
Old 03-08-2011, 01:15 PM
I'll do that and thanks.
Old 03-10-2011, 02:15 PM
Replaced it and it still does it. Now what?
2000 Sportage Fuel Gauge Not Working...HELP!! hottmpr80 Sportage 1 08-03-2010 08:35 AM
2000 Neon - fuse problem - indicators/radio/dome bever1964 Neon | Plymouth Neon 1 01-26-2009 12:47 PM
2000 Venture Fuel Problem mmorales Venture 3 01-25-2008 07:33 PM
2000 Blazer Fuel Problem dgi007 Problem Diagnosis 0 11-29-2006 01:52 PM
2000 neon brake problem WpgK 2nd Gen 00-05 6 10-08-2004 10:50 AM
