Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-28-2011, 05:26 AM
nathyrin nathyrin is offline
Question '00 SL2 bearing/hub replacement?
Is it too difficult to do myself? If not...what tips/tricks can anyone give me?
Old 02-28-2011, 09:30 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: '00 SL2 bearing/hub replacement?
It is more difficult than most cars because the bearing and hub (two separate parts) need to be pressed off/on with a hydraulic press or with an appropriate hub puller. The hub gets pressed out of the bearing first then the bearing gets pressed out of the steering knuckle. There is a large snap ring on the inner side of the bearing holding it in place, so don't forget to remove that before trying to press it out of the steering knuckle.
For installation, the new bearing must be pressed into the steering knuckle first, then the hub gets pressed into the bearing. You can reuse the hub unless you see an obvious reason to replace it.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Durango Hub replacement Pooldude Durango 3 01-15-2010 10:08 AM
99 T&C Front Bearing? SlimJimRD Caravan | Voyager 7 06-03-2009 11:37 AM
wheel bearing hub replacement bugsas99 Aurora 2 03-24-2007 05:19 PM
'96 cherokee 2WD front bearing / hub replacement - need help Kings-x59 Cherokee 0 08-28-2005 08:01 PM
Silverado Wheel\Bearing\Hub Replacement robl99 Silverado 1 01-09-2005 08:28 PM
Tags
bearing , drivetrain , growl , noise
