Old 08-28-2005, 08:01 PM
Kings-x59 Kings-x59 is offline
'96 cherokee 2WD front bearing / hub replacement - need help
I've got the replacement hub/bearing units. The old bearing assembly comes off easy enough, but I can't keep the bearing from spinning when I try to break the nut loose.
This is the first vehicle I've owned where the "spindle" was nothing more than a big bolt through the hub.
I'm assuming the spindle bolt and nut need to be re-used in the new hub.
If anyone has any pointers on this it'd be much appreciated.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
