Old 02-28-2011, 12:38 AM
badpoor badpoor is offline
Unhappy 94 wagon timing belt noise.
Just installed a new timng belt and after I started her up it makes a sound like its rubbing against the cover. I made sure the belt was on correctly and would not rub against anything when I put it in.
This is my first DIY timing belt do they normaly make this type of noise?
Old 02-28-2011, 08:41 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: 94 wagon timing belt noise.
When I did my '93 wagon it made a noise. It turns out the belt was a little too tight. Also, I took my cover off 10 years ago and threw it away.
Nevada Tumbleweed
Old 02-28-2011, 05:27 PM
rhandwor rhandwor is offline
Take the timing belt in your hand in the long stretch. The tension is correct when you can twist it 90 degrees.
Old 02-28-2011, 10:20 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
The tensions should be automatic- it is not adjustable.
If it is rubbing then the plastic cover is not mounted properly. Remove the cover to see where it is rubbing then remount the cover or leave it off.
Old 03-01-2011, 07:15 AM
It is if you tightened it with a pry bar
Nevada Tumbleweed
Old 04-03-2011, 06:16 PM
sorry about taking forever to reply.
when I took it off I loosened the tensioner to much and it fell out.
I thought there was a washer that went behind it because it was where the spring and slider was on the ground. I took it back off and removed the washer and now everything is good.
The pully was rubbing the cover...lol
Old 04-04-2011, 08:57 AM
Good find and great story. One to remember
Nevada Tumbleweed
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
timing belt noise black12 Off-Topic 1 07-19-2004 12:54 AM
