Old 02-26-2011, 11:19 PM
ericcfx1984 ericcfx1984 is offline
00 Alero 3.4, overheats even after LIM
I have bleed the system
it can idle and put out good heat, even let it idle for well over an hour... no issues, it stays right at the middle of the temp gauge
after driving for around 2 miles the heater gets cold, then the temp gauge rises to around 3/4 or so
after that I pull over with the car still running and crack the bleeder and a bunch of air comes out...
then the car cools down again and is fine, but the heater is not, I top off the reservoir again and the heater comes back.
I went thru this 3 or 4 times
finally I tired a pressure test at idle... it does not make much pressure, maybe a little over 5 or 10, but if you rev the engine the pressure drops to the point where it sucks the coolant back down... (negative pressure? suction?)
I have to get this figured out...
the oil is clear, not at all milky, in fact it looks new
Old 02-27-2011, 02:58 PM
Re: 00 Alero 3.4, overheats even after LIM
ok I ran a head gasket test..., you know the tube that you put into the overflow reservoir and you put the blue fluid in the tube, then put the rubber bulb on top, start the car and pump it...
if the fluid turns yellow or even brown then you have exhaust exhaust gases in your coolant...
the fluid stayed blue, so NO head gasket leak...
the coolant is NOT coming out the tail pipe
then I tried a radiator pressure test, got the pressure up to about 10 psi before I noticed a very small leak in drivers side(left) radiator hose, near the thermostat...
I fixed that leak and topped it off...
but it still over heats...
Old 02-27-2011, 04:02 PM
aleekat aleekat is offline
Stuck thermostadt/faulty water pump?
Old 02-27-2011, 04:04 PM
Originally Posted by aleekat View Post
Stuck thermostadt?
it does open up, I could pull it and try it in a pot of water...
Old 02-27-2011, 04:46 PM
inafogg inafogg is offline
have you checked the radiator cap??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 02-27-2011, 05:13 PM
ummm.. no... what should I be looking for?
Old 02-27-2011, 06:08 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Have you tried a compression test to check for a head gasket issue? It sounds like you are getting pressure from someplace since there appears to a alot of air in the cooling system.
On the radiator cap there is none. The cap rated at 15 psi is at the coolant reservoir and the setup is different compared to other GM cars that actually have a radiator cap on the radiator. Doesn't hurt to check it though.
Timeslip 08/12/06
AF Community Guidelines
Old 02-27-2011, 08:24 PM
no I have not tried a compression test yet
so you are saying that there is NO pressure in the cooling system?
the reservoir cap seems fine
also I took out the thermostat and checked it it a pot of water, it opened at 195F
Old 02-28-2011, 10:58 AM
I have been running this test with water... no coolant... my tests show that the thermostat opens at 195F, which is VERY close to water's boiling point
and I have heard that the fans do not kick on until around 220F
what if the water is boiling 212F, meaning that there could be a point in the block where the water is boiling and becomes vapor... this might explain the 'air pockets' coming out of the bleeder when the car overheats...
Old 02-28-2011, 11:17 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
You may be on to something, and it might be a good idea to have coolant in there anyways.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 02-28-2011, 11:19 AM
tblake's Avatar
In God We Trust
Did your car overheat before you changed the LIM gaskets? Or I suppose you didn't run it long enough.
Stupid question, and I don't mean to insult your intelligence because you did just replace your LIM gaskets, but is your t-stat installed in the correct direction? Spring side facing the motor.
Old 02-28-2011, 12:18 PM
yes it did over heat... but it was pumping coolant into the oil at an alarming rate
but i purchased the car like that
What? What? What?!!! How dare you!!! LOL... Just kidding.... but yes it is going the correct way... as far as I know it is too long to fit the wrong way
(at last with the cross over exhaust pipe installed)
Old 02-28-2011, 12:49 PM
tblake's Avatar
In God We Trust
Well, someone over on a different forum replaced his head gaskets and was having issues like you describe. I asked him if he was sure the stat was in the right way and he flew off the handle about how if he knows how to replace head gaskets then he definatly knows how to put a thermostat in. A week or so later he updated everyone that he needed to replace the head gaskets again and that solved his issues. So apparently he had now clue how to install new head gaskets.
Old 02-28-2011, 12:53 PM
tblake's Avatar
In God We Trust
I hate to say it, but had I known you bought it this way and it didn't just start peeing coolant into the oil, I'd have probably went down to the head gaskets right off the bat. As the original owner may have over heated it to the point of bag head gaskets. And since the block is cast and the heads are aluminum, you might want to bring the heads in to get check for warps and machined as necessary.
Old 02-28-2011, 01:21 PM
wow... that would suck...
either way I already did the headgasket/block test (3 times) and it passed...
this is the type of test I ran
http://www.arrowheadradiator.com/hea..._leak_test.htm
also did a radiator pressure test and was able to build and hold pressure no problem
3.4 From 2003 Monte Carlo into 94 Firebird? iamdallas Engine and Transmission 0 03-21-2010 08:39 PM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
alero 2000 overheating v6 3.4 no leak in the head gasket ihatethealero Alero 2 01-19-2010 09:42 AM
99 Alero 3.4 coolant in oil after head and intake gaskets bbullsj Alero 3 01-08-2010 07:06 PM
I have a '99 Olds. Alero 3.4 engine- I think my starter went out!Can you help me? Luminita Alero 1 01-24-2005 12:52 PM
