Go Back   Automotive Forums Car Chat > Toyota > T100
Old 02-26-2011, 12:57 PM
Bearfoot Bearfoot is offline
Question Heater Blower
'93 T100 V6. Heater blower suddenly stopped. There is no heater fuse in the fuse block. Thinking there must be an in line fuse or a fusible link. If so, I need to know where it's located. Any other ideas welcome.
Many thanks in advance.
Stan
'98 Lincoln Towncar - white 100k
'08 Mercury Grand Marquis - maroon 30k
'98 Dodge 3/4 ton, Cummins Diesel, 4 x 4, 4 door, extended cab, long bed. 140k
Old 02-28-2011, 07:39 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Heater Blower
Did you check both fuse blocks? The one behind the drivers kick panel and the one in the engine bay?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-28-2011, 07:59 PM
Re: Heater Blower
I checked both...nothing in either one.
Stan
Old 03-01-2011, 06:00 PM
Re: Heater Blower
Sorry, fourwd1. It was night when I looked. I double checked again today and there is a type B 40A fuse under the hood. The fuse was OK. I pulled it and replaced it with another. Still no blower fan. Now I don't have any idea.
Stan
Old 03-03-2011, 09:15 PM
fourwd1's Avatar
AF -Advisor
Re: Heater Blower
I'm not sure if the T100's are the same, but the mini trucks have a fuse and relay block for the heater tucked up behind the glove box.
You might want to pull the glove box and look around.
89 4Runner - stock
Old 05-06-2011, 10:16 AM
BamZipPow BamZipPow is offline
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow
Wink Re: Heater Blower
I know I'm late to the thread but I would suspect the wiring, connector, or the blower motor itself. It should not be the resistor pack but the connector might have been knocked off or even corroded...so it might be worth yer time to check it out.
Have you checked fer power at the blower motor connector? It will probably look a little brown/burnt.
Have you tried powering the blower motor directly from the battery? If it doesn't run, it's probably the brushes...but it would probably be easier to just replace the blower motor. Just be careful as the motor (if working correctly) has a lot of torque and will spin itself right off the surface if yer not careful.
There is a relay fer the blower motor and it should be labeled "HEATER". It should be located in the engine bay fuse box.
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
intermittent ac/heat blower '00 e320 tpking E-Class 1 07-12-2009 10:51 PM
Heater blower and a/c blower problem scotty47 Escort 5 11-05-2005 07:13 PM
Heater Box/Heater Blower Resistor Block/Vac Schematic NJPagan Cherokee 1 12-14-2004 06:15 AM
heater blower/ac blower newscarver Aurora 3 10-08-2004 04:33 PM
