Go Back   Automotive Forums Car Chat > Nissan > Quest | Presage | Serena
Old 02-24-2011, 05:24 PM
henry79 henry79 is offline
2004 Quest - Takes a long time to heat up in winter
The van will sit to warm up for 20 min in winter before the heat in the van feels warm. If I drive the van before that it does not help to heat up the van faster. The defrost also does not do a good job. I had the thermostat replaced and that has not helped. Any ideas?
Old 02-24-2011, 08:44 PM
tempfixit tempfixit is offline
Re: 2004 Quest - Takes a long time to heat up in winter
How many miles on vehicle? Had the coolant level been staying at proper level before thermostat replacement or have you been adding coolant? What brand thermostat was installed?? Reason I ask is that it has been common lately to get multiple bad thermostats lately from what I have been reading on different forums. How long have you been driving since thermostat replacement?? Possible air in the system Can you tell if the air blend door is functioning properly??
Is your check engine light on? Have you checked for codes, are there any pending codes? Do you have a temp gauge or idiot light? I assume it is a gauge , where does the needle register on the gauge?? Are the coolant fans running continuesly?? Has the ECTS been check for proper function. (Engine Cooling temperature sensor)
01 T&C Takes long time for heater to blow hot air wedgeply Caravan | Voyager 7 11-07-2006 07:15 PM
taking long time in acceleration rubs Camry/Camry Hybrid/Vista 2 11-06-2005 01:42 AM
97 jetta Fan takes long time to run ctuagent117 '97 - '03 0 09-13-2005 08:00 PM
4X4 taking long time to shift jmagerl S-10 2 12-08-2004 07:53 AM
why does my v6 take long time to start when cold? jet_fumes_junkie Camaro Discussions 8 03-23-2004 10:05 PM
