Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-23-2011, 09:10 PM
DaChevyClassic DaChevyClassic is offline
Front Tires
What causes a small dent or dip in the front tires. Do I need a front wheel alignment?
Old 02-23-2011, 10:13 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Front Tires
You mean like cupping? Where there are little 'bowls' in the tread?
Look at your control arm bushings, and also your tie rod ends.
I can also see an improper caster alignment causing this.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-24-2011, 10:18 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Front Tires
Originally Posted by DaChevyClassic View Post
do I need a front wheel alignment?
Probably, but first, have the front end components checked for wear before you do so
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 02-24-2011, 12:18 PM
j cAT j cAT is offline
Re: Front Tires
you talking about the side wall ? the belts can cause a bulge or indentation when the tire hits a hole ..
if the tread has even wear across the face of the tread alignment is correct.
any side wall bulges best take to tire shop..
Anyone got problems with front tires wearing off early? tydog8 Vitara 6 05-01-2009 06:54 PM
Tire wear on the outside of both front tires burnsie629 Rodeo | Passport | MU 2 07-23-2004 02:45 PM
knocking noise from passenger side front tire jeter1955 Grand AM 5 06-15-2004 08:37 AM
problem with front tires CivicSkater Accord/TSX/Accord Hybrid 3 03-17-2003 05:08 PM
Front tire location Toy Man Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 14 04-08-2002 04:31 PM
