Go Back   Automotive Forums Car Chat > Suzuki > Vitara
Old 10-09-2003, 04:45 PM
tydog8 tydog8 is offline
Anyone got problems with front tires wearing off early?
If so post them up here about your car and how many miles they lasted and how they fixed it.
Old 10-11-2003, 09:50 PM
Samurai Hamster's Avatar
Samurai Hamster Samurai Hamster is offline
Thumbs up
Nope tires are wearing ok..........this even after I whacked a rim on the interstate last winter on the way to Florida.
However, the stock uniroyls suck in snow. But the rest of the rig is a tank and zuki makes a great little suv.
Samurai Hamster----turns on a dime and gives nine cents worth of change!
Old 10-12-2003, 07:33 AM
99TrackerConv's Avatar
99TrackerConv 99TrackerConv is offline
Send a message via AIM to 99TrackerConv Send a message via Yahoo to 99TrackerConv
There have been a couple complaints about tire wear on the Grand Vitara, Not so much on the 2dr though. They were saying to adjust the camber +/-2 from the factory specs and it fixes the prob.
99 Pontiac Bonneville SE
04 Hyundai Santa Fe GLS AWD
Old 01-31-2004, 02:33 AM
Zookfool Zookfool is offline
Talking tyre wear
Main problem is the factory cant set up enough camber. You need to slot the holes in the front struts slightly to give more. Where the struts bolt to the front hubs you grind the top hole outwards and the bottom hole inwards. Put a heavy flat washer behind the blot and nut and give the vehicle a wheel alignment.
Try that.
Old 06-16-2008, 05:15 PM
Rob Sam Rob Sam is offline
Re: Anyone got problems with front tires wearing off early?
You may want to consider checking the front wheel bearings. The wheel bearings should be adjustable so it isn't going to cost much to fix the problem.
Old 05-01-2009, 02:02 PM
GODBA GODBA is offline
Uneven tyre wear is common on Vitaras;dig a little deeper on the internet and you'll find many complaints about this problem.
These vehicles fall way short of their perceived image as a supposedly reliable fun-car!
Reliability generally is suspect and parts are expensive compared to the somewhat better competition from Honda and Toyota.
And no I don't work for Honda or Toyota,but do have practical experience of the pitfalls of owning a Suzuki Grand Vitara!
Take heed and save yourself a lot of stress and money!
Old 05-01-2009, 06:54 PM
ricebike ricebike is offline
won't the practice of rotating your tires in a modified-cross pattern, front to back, will help?
i know in other vehicles where FWD is predominant, the fronts wear out way faster than the rears... because most of the weight is on the fronts (engine) and steering will make the edges wear them out faster...
i rotate my tires every 6 months as well as other PM checks i do...
