Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 02-23-2011, 05:51 PM
luboilman luboilman is offline
2004 Drivers side low beam doesn't work hi beam does
The drives side low beam will not work but the hi beam does. Both passenger side lights work. I have replaced the bulb and have checked the fuse (#51 in the engine compartment) and it is OK. Even replaced it with an separate fuse for good measure with no luck. Would appreciate any help an the next step to troubleshoot/fix the problem.
Old 02-23-2011, 08:08 PM
consultIII consultIII is offline
Re: 2004 Drivers side low beam doesn't work hi beam does
the diagram i pull up for a 04 base malibu shows the left low beam fuse to be in the underhood fuse block position 7 and is a 10amp fuse.
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 08:04 AM
Driver Side Door Lever doesnot work pghguy Z3 3 01-25-2006 07:55 PM
Drivers side lumbar support not working David Anderson C/K 4 07-16-2004 05:52 PM
