Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 02-23-2011, 07:20 AM   #1
obiwon
98 chev lumina gear shift issue
98 chev lumina - having issue changing gear shift from park to reverse, park to drive, drive to park, etc.. has gotten much harder to shift the gear shift from anything to anything else. transmission drives fine once I get it shifted to drive or reverse. No problems there. Just moving the gear shift handle from park to drive takes quite an effort. Is this something simple to fix or am I out a bunch of money?
obiwon is offline   Reply With Quote
Old 02-23-2011, 01:20 PM   #2
inafogg
Re: 98 chev lumina gear shift issue
colunm or floor shifter?? w/console shifter some times drinks get spilled
& the sugar gets into shift controls.take apart & clean has solved this issue
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
Old 02-25-2011, 11:57 AM   #3
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
These cables like to get really stiff in cold weather...is it better after the car has been driven? Usually is, if the cable is the problem.
If not, and it's a console shift, take the above poster's advice. I've seen a little bit of coffee and sugar residue keep a 200 pound man from being able to take it outta park, once it dries up in there enough...
Surprisingly, the majority of the sticky is from the slider window with the pointer on it...even a shot of WD-40 on the PRNDL window will usually make a big difference in these cases...
At any rate, if the cable is the problem, as it was with mine, I simply separated it at the junction under the hood by the airbox and shot oil into the sheath...it softened up the dried grease, works fine now...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
2008 Gear shifting issues only when it starts chpearso Grand Cherokee | Grand Cherokee SRT8 5 08-30-2010 08:43 PM
92 Accord hard to shift in and out of park rango25 Accord/TSX/Accord Hybrid 5 11-12-2009 05:57 PM
92 Chev Lumina APV-Stalling in reverse?? sunrisedawn Lumina APV 4 03-24-2009 06:30 PM
92 Lumina Z34 Shifting Issues z34mightymachine Lumina 4 06-09-2008 08:00 AM
97 Astro gear shift issue monteanna M Bodies 1 06-23-2006 11:06 PM
