Go Back   Automotive Forums Car Chat > Nissan > Murano | FX45
Old 02-22-2011, 12:59 PM
autoforum autoforum is offline
engine mount leak
Short story: red oil found under front of car; traced it to front/center motor mount. Probably an ounce of fluid and then it stopped. (Hydraulic and electrical motor mounts! ) No noticeable operation problem at this time.
1. Do I need to replace it or does it really matter?
2. If it must be done, can I reasonably do this job myself with basic tools?
Thanks to all you who read these things like I do!
Old 02-22-2011, 01:28 PM
danielsatur danielsatur is offline
Re: engine mount leak
1) Check both the power steering pump and Transmission for shortage.
Old 02-22-2011, 02:10 PM
No, it's the engine mount itself. Before I ever looked under the vehicle I checked the fluids and all are full. This vehicle is garaged and kept clean so it was fairly easy to see it, clean it up and then verify exactly where the fluid was coming from. No liquid anywhere except on and below the front center hydro-electrical mount. Also the fact that the leakage stopped tells me there is no longer any pressure to push it or fluid left to come out. Furthermore, the dealer informed me that there is no red fluid whatsoever in this vehicle. Although he "lied" because the stock coolant is red, not so in my Murano because I replaced that cheap stuff with green several years ago.
As I research, it's looking like maybe I have to replace all engine mounts at the same time. I sure hope a TSB turns up on this, but for now I just want to make sure that I'm not damaging anything by continuing to drive this way. There are no other indications.
Old 02-23-2011, 05:29 PM
After further research and consideration, I'll have the dealer replace the mount for $500. [$200 for the part and $200 for the labor is what they quoted; I'm not bad at math, just a bit pessimistic and rounding it up to avoid further disappointment at the cashier's window.] I'm a wimp and I don't want to disconnect the catalytic converter and drop the exhaust parts necessary to provide room for the R&R, as I just don't have the heart for rusted, seized and broken exhaust bolts anymore. Apparently the only mount that is hydro-electric is that front mount, so the others should not need replacement. I just hope they don't mess something else up whilst it's in the shop, which is what usually happens and why I generally try to do everything myself.
Old 05-13-2011, 11:12 PM
Well they fixed it, but conveniently misquoted me the price. It ended up being $500 just like I thought. They said they quoted me for an "easier" mount. The guy knew it was the hydraulic one and there is only one like that, but somehow they were able to give me a wrong quote and then not honor that anyway. Well, it was actually $550 + tax but I negotiated for $500 out the door because of the miscommunication on their part and they agreed. Maybe this one will last more than three years!
Engine Mounts williamjbronski LHS 2 01-29-2011 06:07 PM
Rear Engine Coolant Leak? MrPedalsworth Town Car 1 07-21-2010 10:17 PM
engine mount and transmission mounts north450 Bonneville 2 10-11-2005 09:16 PM
front engine mount leaking. rickp Maintenance 4 09-27-2001 08:41 AM
