Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-20-2011, 09:05 PM
armallard armallard is offline
Ac light
My wifes car '05 Buick Regal v6 the last night it was warm she tried the ac and it wouldn't come on now I notice the light is not coming on I fuse? The reason I'm asking and not doing is its hard for me to get down and look since my stroke so i'm going to have to walk her through it the fuse panel lid I found the havac one and she said she changed it but nothing.Any help appreciated
Old 02-21-2011, 05:08 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Ac light
Which climate control system do you have. Manual dual zone or digital automatic (ACC-CJ2)?
Note: The OP has a 2002 Regal.
Timeslip 08/12/06
AF Community Guidelines
The Following User Says Thank You to BNaylor For This Useful Post:
armallard (03-19-2011)
Old 02-21-2011, 08:05 PM
Re: Ac light
I'm not in the car much so I really don't know how can I tell ? The motor is a 3800 seriesII
Old 02-21-2011, 10:22 PM
Re: Ac light
Its adjusted according t o what the degrees she wants she actually don't hit a button for heat or ac seeing now it won't go below 60 degrees its colder than that outside. I've looked all over and can't tell which one it is.
Old 03-18-2011, 05:18 PM
Re: Ac light
Ok her car doesn't have a light just turn it down to where u want it to plus the compressor is not kicking on nor trying I'm going to attach a pic of the inside unit maybe this will help
Old 03-18-2011, 06:58 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Ac light
Does the temperature display flash for a couple minutes after you start car?
The temperature display is where you see the 70 in your photo.
If so, you have a code set. It would be good to know the code.- you can have it read
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-18-2011, 09:12 PM
Re: Ac light
No it don't I just checked it, ran it down to 60 but never got cold. Any other ideas. Appreciate all the help I could get.
Old 03-19-2011, 09:06 AM
brcidd's Avatar
Re: Ac light
If you are in "auto" mode and you've dialed up 60 degf and it is above 60 deg outside, then you should hear the compressor come on and feel cool air out the vents, if not, then time to get the a/c checked- for pressures and electrical issues.
'99 GMC Yukon
The Following User Says Thank You to brcidd For This Useful Post:
Old 03-19-2011, 12:07 PM
Re: Ac light
I want to thank everyone for their input on this looks like its beyond me time for a cert. mech. again thanks
Old 03-22-2011, 06:10 PM
Re: Ac light
Is some kind of fuse box under the hood for the air. The compressor is running no cold air and al this happened all of sudden
Old 03-22-2011, 10:14 PM
BNaylor's Avatar
Re: Ac light
Yes. The AC clutch fuse located in the engine compartment fuse box and a relay. However, the AC Clutch will not turn on if the system is very low on R134a refrigerant. There is a low/high pressure switch in the system for compressor safety.
Timeslip 08/12/06
Old 03-23-2011, 09:39 PM
Re: Ac light
No fuses under the hood are blown the clutch is fully kicking in when she kicks the thermo down. I put a code reader today and it showed two-------p0102-----p0128 when I looked them up myself I don't think it has anything to do with the ac,
Old 03-23-2011, 10:41 PM
BNaylor's Avatar
Re: Ac light
Neither DTC is relevant to your A/C issue. One is MAF sensor and other engine temperature related. So to recap you are not getting any cold air from either the driver or passenger vents since it is dual zone? Have you checked your refrigerant charge at the low side port?
Timeslip 08/12/06
Old 03-23-2011, 11:31 PM
Re: Ac light
I gues I'll gave it checked with someone with gauges because as long sd she has it long its(clutch) fully ingaged
Old 03-23-2011, 11:35 PM
BNaylor's Avatar
Re: Ac light
Thats sounds like a good plan to me and good luck!
Timeslip 08/12/06
2005 Impala...all lights turn off!! pieps57 Impala | Impala SS 2 03-04-2011 12:07 PM
blows day time running light /back up light fuse. Yamagirl F Series 1 02-24-2011 11:36 AM
altezza style lights such as tail lights, corner lights, guard flashers, head lights sportslights General Discussion 1 05-29-2005 11:03 PM
altezza style lights such as tail lights, corner lights, guard flashers, head lights sportslights General Discussion 0 05-29-2005 02:01 AM
altezza style lights such as tail lights, corner lights, guard flashers, head lights sportslights Classifieds 0 05-29-2005 01:59 AM
