Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-20-2011, 03:50 PM
pieps57 pieps57 is offline
2005 Impala...all lights turn off!!
My Grandma has a 2005 Chevy Impala, 2 times in the last month she has been driving at night and all the lights have gone off. She pulled over and "flickered" the high/low beams and she said after about a minute they came back on.
I am wondering if this is the switch in the dash(to the left of the sterring wheel) that turns the lights on or off?
Or is it something else?
Thank You!!
Old 03-03-2011, 08:18 PM
SierraK1500's Avatar
SierraK1500 SierraK1500 is offline
Exclamation Re: 2005 Impala...all lights turn off!!
Have the Dealer or a reputable shop run some diagnostics on the car and see if
there are any codes.
The BCM (body Control Module) is the culprit for about 95% of the problems from headlights to the car refusing to start.
Check all connections to the BCM and make sure they are right.
Also check the headlight switch in the dash for problems and the emergency brake, when applied the headlights go off too. Make sure that is fully released.
Good luck.
John
Old 03-04-2011, 12:07 PM
j cAT j cAT is offline
Thank You!!
If she uses the hi/low beam on the steering column often this may be worn. some have had this to be the headlight dash switch also.
next time it fails see if moving the switches slightly can get the headlights to come back ..
since it is working they will throw parts at it ..
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
2005 Impala making helicopter noise, even when off PLEASE HELP!! katafan1 Impala | Impala SS 2 08-06-2010 07:23 PM
98 Olds electrical - interior lights turn off 63johnm Silhouette 0 07-12-2010 12:32 PM
How do I rewire my 1995 Magna so the lights turn off when the car turns off? Captain_Glen General Discussion 1 07-11-2010 06:55 PM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
