Old 02-18-2011, 02:14 AM
shmolloydvm shmolloydvm is offline
Unhappy Please help! 99 Escort ticking then stalled, cranks but won't start
Please help! My 99 Escort has been awesome- one of the best used cars we've ever had but now it's having its first problem: I noticed a new ticking noise so checked the oil & it was fine. Drove about 3 miles (to the store) & it started back up normally. Got about halfway home & it stalled. Now it cranks but wont turn over. Obviously Im hoping it's something easy/cheap to fix. Someone told me maybe it was a timing belt. What else could it be? Thanks!
Old 02-18-2011, 08:19 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: Please help! 99 Escort ticking then stalled, cranks but won't start
My first thought was timing belt.
Nevada Tumbleweed
The Following User Says Thank You to AzTumbleweed For This Useful Post:
shmolloydvm (02-18-2011)
Old 02-18-2011, 12:51 PM
702VegasLife's Avatar
702VegasLife 702VegasLife is offline
Just replaced my timing belt on my 02 escort, Ticking I had went away, I would look at the timing belt for cracks or it may have snapped if it's stalling. Good luck! keep us updated
Old 02-22-2011, 03:34 PM
denisond3 denisond3 is offline
If the timing belt still looks like its in place and turning the cam - i would try a compression test. All 4 cylinders should be nicely above 125. More like 150 after the engine has rotated for six 'compression pulses' per each cylinder.
Old 06-19-2011, 01:04 PM
Jamesjjr9110 Jamesjjr9110 is offline
Unplug your MAF sensor and try to start it. My 91 Escort did similar to same thing (except it would turn over, attempt to start and run for a second or two very poorly and die) and I replaced fuel pump, coil, wires, plugs, air filter, fuel filter, checking timing belt, all sorts of stuff and it turned out to be the MAF sensor.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
94 Escort Cranking, but won't start ang76 Escort 1 04-26-2005 08:13 AM
2000 Z24 engine cranks but won't start, stalls sometimes jballs Cavalier 4 01-21-2004 06:47 PM
Help! Car Cranks But Won't Start, Again!!! branman_crx_guy '88 - '91 Civic | CRX | Wagon | Shuttlee 16 07-30-2002 10:36 PM
Tags
'99 , cranks , escort , stalled , ticking
