Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 02-15-2011, 10:20 AM
57corv 57corv is offline
Overdrive Off function
I have a 2006 Focus with automatic. When I first turn on the ignition the OD Off light comes on as it should. When the car shifts into Overdrive and I press the button on the shift handle, nothing happens. The OD light does not come on and the car does not shift out of overdrive. Is this an option not on all Focus models? In the driver's manual in the Instrument Cluster section it lists the Overdrive off (if equipped). I would assume that all automatics had this function especially if the button was on the shift handle and the light was on the instrument cluster.
Overdrive stoped working / Flashing O/D off light netwrkgod Windstar 16 09-21-2010 12:00 PM
How do you take the overdrive off in an S10? Ducaire S-10 9 04-18-2005 10:11 PM
Overdrive off on matrix, going faster ? trixareforme Corolla/Matrix/Voltz 3 03-23-2005 09:39 PM
Overdrive off on matrix, going faster ? trixareforme Engineering/ Technical 10 03-06-2005 12:41 PM
Driving with Overdrive off or on? SoftFiZ Accent | Verna 1 08-16-2004 02:51 PM
