Old 04-18-2005, 12:32 PM
Ducaire Ducaire is offline
How do you take the overdrive off in an S10?
I drive a 1990, automatic S10. Is there an overdrive on it? And if so, can it be turned off an on? Sometimes I wonder if I'm not driving with it on.
Old 04-18-2005, 07:06 PM
OverBoardProject OverBoardProject is offline
Banned
Re: How do you take the overdrive off in an S10?
If your truck has the origional type transmission you do have overdrive.
If it's anything like my 85 Put it in D, or #3 and you won't be in it. the overdrive symbol is a d with a O around it.
Old 04-18-2005, 08:10 PM
Re: Re: How do you take the overdrive off in an S10?
But that would be like putting it in a lower gear, wouldn't it? I thought overdrive was where the engine revs higher so it has more power to get up hills and stuff like that, and was wondering whether I could take mine off because there aren't any steep hills around where I live.
[I don't know much about automotive (and there is a D with a round box around it )]
Old 04-18-2005, 09:12 PM
Banned
That D with a round box is where you will want to leave it then, except if you tow anything more than an empty trailer, or haul a heavy truck full of stuff. Then you want to just use the D setting, or #3.
Old 04-18-2005, 09:19 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
overdrive is a lower gear so you burn less gas, ie the overdrive knocks the rpm's down, harder on the moter and transmission if your towing and or going up and down hills, if you live in a flat area, od is fine, if you want the max life out of your moter and tranny, keep out of the gas, and dont tow in overdrive, that is the quickest way to fu*k up a good tranny.
Old 04-18-2005, 09:20 PM
smoothchev smoothchev is offline
Lightbulb Re: Re: Re: How do you take the overdrive off in an S10?
Overdrive is exactly the oposite. Most newer manual and autmatic transmissions have an overdrive. The definition of "overdrive" is; any gear ratio less than 1:1. Take your S-10 for example. It has a 4 speed automatic trans. 1st and 2nd gear are a higher ratio than 1:1, probably like 2.75:1 or so. 3rd, however, is actually not even a gear! All of the internals of the trans esentially "lock" together, creating a 1:1 ratio. Now that we have that out of the way ;-o 4th gear, or overdrive, is a gear AFTER 3rd. It cannot be removed as it is a gear inside your transmission. The actual ratio might be around 0.75:1, allowing the engine to actually turn slower than the output of the trans. I imagine they got the name overdrive since the output of the trans is spinning faster than the engine in that particular gear. This is a little longer than I wanted it to be, sorry guys (and gals).
Old 04-18-2005, 09:29 PM
Banned
And of course you can become even more confused looking into the rear end ratio, and tire sizes. The larger the tire, or the lower the gear ratio in the differential the lower that your engine will rev at highway speeds.
You don't want to change this so much that your engine is almost at the stall point at highway speeds
Old 04-18-2005, 09:30 PM
so the torque converter is locked up in 3rd?
Old 04-18-2005, 09:34 PM
Banned
I might be wrong but I believe that the torque converter lockes up in all the gears shortly before the shift point
Old 04-18-2005, 10:11 PM
It is actuall after it shifts, and it'll only lock up in 3rd or OD, depending of course on which gear you have selected. The throttle position factors into the equasion, too. Hence, more throttle, later lockup.
