Old 02-26-2005, 11:42 PM
trixareforme trixareforme is offline
Overdrive off on matrix, going faster ?
Ok, i have a 2003 matrix xr. when im on the freeway trying to see how fast i can go , i feel i have more power when i have my over drive off. then when my Rpms get to high, i switch my overdrive on. then keep accelerating. is this bad to switch my overdrive on while going this fast ? plus toyotas are automatically put on overdrive, is it bad for me to drive it off ?
Old 02-27-2005, 12:23 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Overdrive off on matrix, going faster ?
Nope. The faster you rev, of course, the greater the wear on the engine, but that is true of any gear or any speed. The reason the acceleration feels stronger is twofold; first, your engine makes more power up high in the revs, and second, the higher gears have less torque multiplication, so the net torque making it to the wheels is reduced by about 1/4
Dragging people kicking and screaming into the enlightenment.
Old 02-27-2005, 05:03 PM
so its ok to switch my overdrive at a high speed ?
Old 02-27-2005, 05:05 PM
ohh and thanks for all ur replys dude u help everyone out , thats cool, ur a like a automotive information Wiz.
Old 02-27-2005, 08:48 PM
curtis73's Avatar
Re: Re: Overdrive off on matrix, going faster ?
Wow, thanks. I wouldn't go as far as Wiz, but you're welcome
Its fine to shift your tranny in and out of OD. During shifts is when 90% of the wear occurs in an automatic tranny. They're of course designed to handle it and the wear that occurs during the shift is incredibly minimal, but it stands to reason that a transmission has a certain lifespan and the fewer shifts, the better. Most cars also have a protection factor built into the computer that it won't let you shift down if the shift would cause the engine to rev past redline so for the most part you can't damage it. You'll just be accelerating wear on the components.
Old 03-05-2005, 02:05 PM
Quickshift Quickshift is offline
Send a message via AIM to Quickshift
if a transmission is 4 speed w/OD is the OD gear 4th? or is it one more gear so it becomes a 5 speed
Old 03-05-2005, 05:45 PM
solaris=amazing's Avatar
solaris=amazing solaris=amazing is offline
A 4 speed Automatic OD transmission i believe is 3 gears, with overdrive as a 4th gear-i believe it's a band though, so technically it's a 3 speed trans, with an extra band-4th(or overdrive).
I can be wrong... Curtis is the man for answering questions.
BTW, when i'm going to be driving on normal, light to light streets (not over 50mph) i'll keep OD off, this does make your gas mileage go down though...atleast it did with me, i got a 4.6L v8 Tbird that eats up gas more with od off. When your going over 50mph for a while though, leave OD ON, believe me, cause you will take a hit in the wallet-because of the gas.. If you have alot of people in the car, leave OD off under 50..over 50...put it on.
"And Death Shall Have No Dominion"
Dead men naked, they shall be one
With the man in the wind and the west moon
When their bones are picked clean and the clean bones gone
They shall have stars at elbow and foot
Though they go mad, they shall be sane
Though they sink through the sea
They shall rise again
Though lovers be lost love shall not
And death shall have no dominion.....
....Dylan Thomas....
Old 03-05-2005, 05:48 PM
PS trixareforme, yeah my car feels more punchy also with od off, i love the power.
Someone told me when you take off o/d, you are just eliminating the final gear...and there is NO differance in speed....BULLSH*T..lol... If i'm going 60/70mph..and punch it, with o/d off..MUCH faster. It's what curtis said, about the rpm's staying higher near your power band. My torque peaks at 3200..
Old 03-05-2005, 05:55 PM
curtis73's Avatar
You're right Solaris... Its a four speed tranny; fourth is the band which overdrives it.
Old 03-06-2005, 12:28 PM
thx for clearing that up
btw when you put OD off your basically downshifting which raises your RPM therefore giving you more power. For example my parents have an 03 Rav 4 on the highway if there is an incline, like the one on I-15 to vegas from socal you put OD off and you can get up 90 or 95 on those inclines.
Old 03-06-2005, 12:41 PM
curtis73's Avatar
... And in theory, you'd be in 3rd (drive) anyway since the automatic tranny would shift there for you. There is no difference between physically putting the shifter in the third gear, and the transmission doing it on its own. It doesn't have more power if you put the shifter in D vs. letting the tranny do it for you. In general, it makes sense to put a tranny in OD and let it shift on its own unless its hunting around gears a lot.
