Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 02-13-2011, 06:29 PM
panteli2011 panteli2011 is offline
90 SC Flashing headlights/odometer
1990 Thunderbird SC 3.8L Supercharged
While driving the car with the headlights on after about 5 minutes or so the lights will start flashing on and off uncontrollable. flashing stops when lights are turned off and only continues after being on for 5 min.
Thought i could be a short but im not too sure.
The odometer stopped, opened it up and found the plastic gear inside with some broken spokes. replaced it with another plastic gear for it to only happen again. any idea on replacing it or after marketing it, i don't care which i just need it fixed
Old 02-14-2011, 05:00 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 90 SC Flashing headlights/odometer
Sounds like it's time to replace the headlight switch. You haven't added any other lights to the circuit have you? You will probably have to replace the speedometer cable also. Disconnect the cable at both ends and try to turn it. It should spin freely with no binding.
The Original 97Bird
Old 02-14-2011, 06:41 PM
No the car is completely stock ive just changed out the bulbs cause they burned out
Old 02-15-2011, 05:47 PM
97Bird's Avatar
If you installed higher wattage bulbs then stock that could be your problem.
The Original 97Bird
Old 02-15-2011, 08:45 PM
Its the right wattage i made sure to check that
Old 02-17-2011, 12:59 AM
NWRyder NWRyder is offline
I have been having the exact same problem with my 93' LX. I have installed higher wattage headlights though... strange thing is that it's only the lows that flash, the hi-beams work completely fine. Guessed that it may have been a switch, any luck on fixing this problem?
Old 02-17-2011, 05:45 AM
Havent actually been able to try it out due to the car being stored for the winter but i am going to try as soon as possible.
HID Headlight Flickering Blink Flash poppeman 9-7x 2 07-24-2012 10:32 AM
Flashing headlights mustangsally40 Mustang Talk 10 01-27-2005 06:41 PM
Flashing headlights lookingfor3 Cougar 1 01-04-2005 03:11 PM
flashing headlights K. Connor Caravan | Voyager 6 09-21-2004 10:20 PM
Please Help!, Flashing Headlights FLIPSIDE91 Dakota 4 09-20-2004 09:23 PM
