Old 09-21-2004, 02:40 PM
K. Connor K. Connor is offline
flashing headlights
Can someone help me, my 1997 dodge caravan battery went dead and now since its been replaced i get flashing headlights. I saw from a previous posting that [email protected], found aposting on your website how to reset somehting and can't find it. Can you help me?
Old 09-21-2004, 02:42 PM
mprtech mprtech is offline
Re: flashing headlights
If you have vehicle theft security you would need to close all doors and cycle the key in the drivers lock cylinder.
Old 09-21-2004, 02:45 PM
I do have security locks, but don't use them,I'm sorry what does cycle the key in the drivers lock cylinder mean?
Old 09-21-2004, 05:28 PM
Put the key in the drivers door and turn it to lock and then to unlock.
Old 09-21-2004, 09:06 PM
Post Re: Re: flashing headlights
Oh, OK> Sorry for the stupid question. I tried that, still no luck. I failed to mention that the inside lights were also flashing:a/c, wipers and recirc> I read in one if your other replies that when the inside lights...air condition, recirc, & wipers were flashing, was to try to reset them, by pushing two buttons at the same time...recirc and A/C, I did just that and got the multiple lights to quit flashing, but still have the a/c and recirc light flashing. My air condition is not blowing real strong. I think it could use a shot of freon. I had some put in a few moinths ago and it ran out already. My friend said it may have a blockage in the line or something. Does this sound like it may affect it?
Do you htink if I try the I4 Code you mention in previous messages, it may fix the headlights?
thanks so much for your help!
Old 09-21-2004, 10:19 PM
I'm not sure what you mean by the I4 test? The ac lights are still blinking because you still need to perform a ac cooldown test.
Old 09-21-2004, 10:20 PM
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
Set Blower motor ON HIGH
Set Mode position to Panel
Open all A/C outlets
Set Temperature to Cold (Both slide pots if equipped)
Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light)
RESULTS:
All LED's will turn on for 5 Seconds
Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
After all tests have passed, Calibration Diagnostics and Cooldown can be run separately.
COOLDOWN TEST ENTRY
TO INITIATE TESTS:
Depress WASH and A/C simultaneously for 5 Seconds
NOTE: Prior to start of test, If the evaporator is already cold, the system will fail test. To correct, operate system with A/C OFF and the blower motor ON high for three minutes prior to starting test.
RESULTS:
Cooldown Test is running when A/C and RECIRC. are alternately flashing. If A/C and RECIRC. are flashing simultaneously, Cooldown has failed.
