Old 12-01-2004, 10:24 AM
mustangsally40 mustangsally40 is offline
Unhappy Flashing headlights
I have a 1998 Mustang. Coming home from the beach, my headlights starting flashing on and off for no apparent reason. The highlight swich on the dash seemed to be warm. Was there a recall on this problem, or is it an electrical issue that has to be tracked down? The wife is going nuts, it's here car. Help!!
Old 12-14-2004, 09:27 AM
Riverspirits Riverspirits is offline
Unhappy flashing headlights
I had the flashing headlight problem about 4 years ago on my 1994 Ford Mustang. (Makes for quite a "thrilliing" ride after dark on country roads -- and NOT in a good way!)
At that time it was the big switch on the stalk off the steering column that controls the bright lights, turn signals and wipers -- once that was replaced, the problem was no more...
Until this past week -- I'm having it again!
This time, I was in a really bad spot for it with still a ways to go before home, so I experimented and discovered this -- if I pulled back on that stalk switch (which flashes the bright lights) the brights would stay on (they wouldn't stay on if I pushed the stalk to engage the bright lights). I am _guessing_ that it's that switch again, and it's in the shop to get that replaced... But of course, now that it's in the shop the lights are staying on just fine. If you find out anymore, please let me know; if I do, I'll do the same for you. Good luck! (and don't drive after dark 'til you get it fixed!)
-Anne
[email protected] -or-
[email protected]
Old 12-14-2004, 09:58 PM
glowstang93's Avatar
glowstang93 glowstang93 is offline
go to www.50resto.com then go to the electrical/lighting products, you will find a fix for this problem, it has something to do with the switch and the driving lights on GT's.
1993 Mustang LX
2.3 4 cyl 105 hp
Reef Blue
Mods:215/60R15 Tires, 3G Alternator Upgrade, Removed Air Intake, K&N Air Filter, Tinted Windows, Upgraded to JL Speakers, JVC KD-AR3000 HU
Sealed Box with 2-10" 4000 MTX Road Thunder Subs, MTX Road Thunder RT202 Amp, JL 3.5, 6x8, and Pioneer 6.5 = 6 speakers, UnderBody Neons, Corbeau Sport Seats w/lumbar support,KYB GR2 struts/shocks
Old 12-14-2004, 10:52 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Re: Flashing headlights
What your talking about "Blinky" the affectionate term used for the Fox-bodies fun lil stock headlight/foglight switch that often fails is something different.
He has a 98 so it's a similar but different problem.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 12-15-2004, 08:33 AM
Red 99 Mustang's Avatar
Red 99 Mustang Red 99 Mustang is offline
Send a message via AIM to Red 99 Mustang
i have the same problem some times...on my 99. it was just after i got my subwoofer put in (2 10's with a 1200w amp...12's wouldnt fit ) i was goin from circuit city to go pik up my gurlfriend, and all a sudden the lights started flashing 4 no reason. it was like that for like 2 days, every so often it would blink, but then it stopped, that was a copuple months ago... but then like 2 weeks ago it did it again...but then it stopped n it hasent doen it since...i dunno those things r like posessed...lol
Old 12-20-2004, 12:25 AM
Future303 Future303 is offline
Funny you guys mention Headlight problems.
I'm having a strange issue here:
I have HID Headlights, but when I connected them to the Low Beam connectors, they won't power on when the motor is running. So I connected them to the High Beam connector and they seem to be working fine, as long as I have the switch in High Beam Mode.
Problem I have now is that occasionally when I switch the left turn signal, the headlights will turn off for 2-3 seconds, and then turn on again. It happens intemittently, and more often in colder weather.
Any clues what that could be?
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 12-22-2004, 02:29 AM
rezmore3333 rezmore3333 is offline
my 88 gt had the same probs it was the light switch for the head lites it started toasting the wires might have been a ford problem check out your contacks and wire clip harness to the switch
wierd deal
Old 12-22-2004, 09:25 AM
^^^I'm guessing that the above wasn't a reply to my question?
Old 12-27-2004, 08:02 AM
Smile Flashing Headlights
I had my headlight switch replaced last week. (The switch on the dashboard) No more "blinky". My mechanic tells me that it is a Ford problem. He keeps a hand full on the light switches on hand and replaces them on a regular basis on other Fords, as well as, Mustangs. Thanks again for everyone's input to resolve this.
Old 01-27-2005, 10:55 AM
I'm back! The headlights starting blinking again. I have noticed that if you hit your dimmer switch to high beam, they will stop. Wait 5 minutes, if the person in front of you doesn't mind, and go back to regular lighting. Sometimes it ocurs again.
Old 01-27-2005, 06:41 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
The flashing can also be caused by a over-charging of the battery or the failure of the alternator. You might want take a look at that.
I had the same problem you all described, and it was the battery being over charged. matter of fact, the battery started to leak from the top because of it
My ride at my site Silverstangs.
