No High on ftront HVAC blower..
99 Suburban K1500 w/5.7. The three lower speeds work, but the front blower does nothing when switched to high. What could this be?
Also, while I'm posting, the outside air blend door is getting flaky. Is it a vacuum diaphragm down there, and how hard is that to change out? Thanks
2004 Ford Excursion 6.0 PSD 1999 Chevy Suburban K1500 LT 5.7l |
Re: No High on ftront HVAC blower..
Blower motor: When you switch to high a relay is pulled in to supply a full 12v to the blower. So it could be any or a combination of 3 things. The fan switch, the relay or the #3 50a BLOWER fuse in the underhood fuse panel. Relay is located on top of the heater plenum behind the glove box.
Blend door: Is most likely electrically controlled and the issue could be debris blocking the door from full movement.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
| The Following User Says Thank You to 777stickman For This Useful Post: | ||
william_04_x (02-12-2011)
Thanks for the quick reply, stickman. I had checked the underhood fuse earlier, and it was okay.
I pulled out the glovebox, fiddled around with the blower connections, and tapped on the relay. Next key cycle it worked fine. Intermittent electrical problems are my favorite. ![]() I haven't checked the blend door yet.
I would guess the relay.. at this age and use , the blower motor will have worn internal brushes. as these wear down the motor will no longer run. the motors also when old , draws more current , as they are less effecient. |
