Old 02-10-2011, 11:50 PM
Sward83 Sward83 is offline
1997 Silverado Ext Cab 4x4 won't engage
I purchased a 97 Silverado Ext Cab last Spring for my daughter. The 4x4 engaged properly at that time, but we haven't had any reason to engage it again until recent snow storms. Just my luck, the 4x4 wouldn't engage. When I press the 4hi or 4lo buttons, they only flash and the 4x4 won't engage. I've checked both the No. 2 and 24 fuses and both are fine. When I looked at the actuator, it was the updated, non-thermal version with a 3-pin connection. I don't know if it was OEM or if a prior owner had installed it. When I unplugged the actuator, it had power to the light blue wire when the 4hi button was pressed, but there was no power to the brown wire. I haven't checked with a volt meter, but from what I've read, I should have power to the brown wire whenever the key is in the "on" position. I've now exhausted my knowledge from reading many posts. Can you give me any suggestions as to what I should try next? I'd rather not take it to mechanic if it's a relatively simple fix. Thanks for any help!
Old 02-11-2011, 10:20 AM
777stickman 777stickman is offline
Re: 1997 Silverado Ext Cab 4x4 won't engage
This sounds like the encoder motor on the t-case is not moving to the commanded position. It's a pretty common issue. The front actuator won't get any signal to engage if the t-case is not shifting.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-11-2011, 10:34 AM
Thanks for your response. Should I first check to see if the encoder motor is getting power? How/Where do I do that?
Old 02-11-2011, 06:45 PM
This is out of my '98 manual, so your '97 may be different.
Look for 2 connectors on the E/M, one with 6 wires & one with 2 wires. My '98 manual shows the 2 wires as red & black. With the key in the "run" position back probe these 2 wires for power with a test lite. This will take 2 people as one has to be probing while the other is pushing the selector buttons.
Keep in mind that the voltage signal to the E/M will only last 3-4 secs if the t-case control module (TCCM) does not get a feedback signal from the E/M that it moved to the commanded position. That's what the flashing lite on the selector panel is telling you.
57 Chevy 210
Old 02-13-2011, 12:34 PM
MikeD266 MikeD266 is offline
With all of the funky routing of power in these trucks you may want to take a few minutes, pop the auto trac switch and examine the PCB for cracks as well. I've re-soldered mine twice in two different places now in the last 10 years after hairline cracks appeared.
has anyone installed subs in their 88-99 silverado EXT cab highroller#2 C/K 8 08-10-2006 02:58 PM
2002 Silverado Ext. Cab, 4x4, 5.3L rear brake pads mrsparky637 Silverado 4 02-02-2006 04:51 PM
2002 Silverado Ext. Cab, 4x4, 5.3L rear brake pads mrsparky637 Silverado 0 01-31-2006 10:33 AM
99 Silverado ext cab wind noise anthonyball C/K 17 02-08-2004 04:26 PM
In-progress Chevy Silverado ext. Cab calvin3 WIP - Street 23 10-14-2003 08:50 PM
Tags
4x4 , actuator , silverado , volts
