Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 02-07-2011, 06:17 PM
smitty782 smitty782 is offline
Water pump?
Just bought this 05 GMC envoy and it has a belt noise the belt is new and the tension pully is new. if you squirt the belt with belt dressing it goes away for a moment and comes back can anyone help?
Old 02-08-2011, 02:36 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Water pump?
One of the accessories is causing the slip, but squirting the belt won't pinpoint it since the belt eventually winds around all of them.
A better way would be to remove the belt and try to turn each of the accessory pulleys by hand (except the crankshaft, of course) and the idler and tension pulleys. They should all be easy to turn and not make any noise.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
The Following User Says Thank You to jdmccright For This Useful Post:
smitty782 (02-08-2011)
Old 02-08-2011, 03:32 PM
Re: Water pump?
Thanks will try this. I just mention the wp cause I read on a review that water pumps where common problems on the 05
Old 02-09-2011, 10:04 AM
jdmccright's Avatar
The RustBuster
Re: Water pump?
Haven't seen anything in here to confirm or dispute that, but typically they will fail by leaking through the shaft seal rather than the bearing itself. Trying to spin it by hand would be the acid test. But to lend credence to this, my neighbor had to change his water pump in his Colorado last year...same part number as the 6-cyl Envoy (you don't mention your engine size).
A new pump will feel some friction and not free spinning yet smooth. A well-worn but still good will spin easier but still feel and sound smooth. But if the bearing is failing, the pump will feel like there is intermittent friction and you might be able to hear it, too, as a scraping sound. Of course, if there is coolant coming from the weep hole then it is bad regardless of the bearings.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 02-09-2011, 11:13 AM
Scrapper Scrapper is offline
AF Premium User
Re: Water pump?
read your can of belt dressing as your not suppose to use it on serp belts not trieing to be nasty to you.
good luck.........
scrapper.........
The Following User Says Thank You to Scrapper For This Useful Post:
smitty782 (02-09-2011)
Old 02-09-2011, 07:20 PM
Re: Water pump?
Sorry its a 4.2 and thanks I will take the belt off and try to locate noise
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
