Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-05-2011, 09:20 PM
jocro jocro is offline
steering
1999 regal......My power steering was acting up so I checked the fluid level. Level OK Still every once in a while it got hard to turn. Now it seems like there is no power steering when I am turning left only. Is there some kind of directional valve going bad in the PS pump or what? No obstuctions around the wheels..........Any help greatly appreciated...........JOE
Old 02-06-2011, 01:29 AM
smonroe86 smonroe86 is offline
Post Re: steering
Click here for other thread on same discussion
Other than that I am asuffering the same problem but
I am hard headed and don't believe its all rack and pinion because mine is not leaking fluid and gets hard headed at times like me. BUT the gears are not destroyed at all. I keep jacking with it and making it worst. But I switched out the fluid to lucas power steering. No problems, but I and now discovering an air leak, but NO FLUID. So tomorrow I will keep investigating. But I have cleaned everything with solvent, but this snow is slowing me down and getting me sick.
Today though I am to the point that it may be a hose it may not. But as soon as the sun raises, I am putting the car on jack stands and removing my tires and bellows boots and checking the entire system. I just replaced my steering pump couple days ago. But that made it worst. So "I BELIEVE" its an air problem. :runar ound: I will continue, but you must tell all sytoms you are having. CLICK HERE FOR THE RACK AND PINION PROBLEM TREE This site is the reason also I am failing to believe my rack and pinion are bad on my 99 Regal!!!
Old 02-07-2011, 11:06 AM
Re: steering
Got another opinion on the problem................rack and pinion...... not sure what to do now.........will it fail completely or just get worse? JOE
Old 02-08-2011, 10:54 PM
Re: steering
BINGGGGOOOOO!!!!
It is not the rack and pinion. People are feed wrong information everywhere. So I gave in and went to a NAPA Automotive shop. Talk to them and they looked at it. Comes out that the strut bushing mounts SIEZED up. So I said haaa yall fix it lol.... So they are replacing all my suspension because it is waaaay to cold here in lovely kansas and I dont have the special tools to not jack up the alignment anymore than I have. So I am paying them $600 to redo it all both left and right side. My Regal will be ready in the morning!
The worst it can get is, you will have to drive just to turn other than that you cant turn at all while sitting because the bearings are shot!
Old 03-16-2011, 07:39 AM
Re: steering
UPDATE............................Changed rack and pinion.. all is well Thanks.....JOE
Steering Wheel Repair JDatx512 Tacoma 0 03-30-2009 12:55 PM
Difference between a '94 and '95 steering column? Steering column guard.. telepunk Trans Sport 1 01-18-2005 01:14 PM
Loose Steering wheel/ Steering Slop & Tranny P1870 pkspx01 Blazer 10 11-02-2004 03:30 PM
Power steering steers hard to the left Grayl in Phx Aurora 5 01-19-2004 02:49 AM
Steering Wheel Or No Steering Wheel CivicLx Car Audio 8 01-25-2002 03:02 AM
