Go Back   Automotive Forums Car Chat > Fabrication & Tools > Machine Tools
Machine Tools Learn about metal lathes, milling machines and CNC tools.
Old 02-04-2011, 06:57 AM
Pippin1974's Avatar
Pippin1974 Pippin1974 is offline
Questions about CNC milling machine
Hi everybody
I want to introduce myseflt into machining, I'm looking for design my own bikes or parts of bikes an machine it in plastic or methacrylate or machine the molds and then use resin to cast.
I don't have so much idea what I need or what I have to look for....can somebody tell me what I need? what machine could do that job? and also if someone dos the same as me with cars, could you say me what software do you use??
Thanks a lot!!!!!
Old 02-28-2011, 05:56 AM
gulfclk's Avatar
gulfclk gulfclk is offline
Re: Questions about CNC milling machine
I do this type of work as well and I use a Sherline 2010-CNC mill with CNC Rotary table.
To command the machine, I use Mach-3 software. cheap and very easy to use and set-up.
To convert the CAD drawings into mill programs (post processing), I first used Lazycam, but as I went into more complex milling, I bought Deskproto.
Hope this helps you!
Superdetailling is not a crime!
a lathe or a milling machine?? idgeek Machine Tools 1 04-05-2010 06:38 AM
5 Axis CNC Mill systems Adam Baker Machine Tools 4 12-07-2008 10:08 PM
CNC mill/lathe anyone with one making wheels? white00gt Machine Tools 4 11-29-2008 08:45 PM
Milling Machine? robrex Machine Tools 15 10-16-2008 08:21 AM
model lathes/milling machines brad_26 Car Modeling 12 01-06-2005 05:21 PM
