Old 01-01-2005, 08:22 PM
brad_26 brad_26 is offline
Send a message via AIM to brad_26 Send a message via Yahoo to brad_26
model lathes/milling machines
who has them and how do u like them i was think about getting them any one have any ne prefrences on the make of them
Old 01-01-2005, 09:44 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: model lathes/milling machines
Im working on getting a medium size lathe, for heavy machining. Roughly 9x20 to 11x30. Most model lathes are 7x10 to 7x14. Sherline makes some pretty good lathes for models, but I dont think you could get away machining big parts for several hours at a time.
Also looking at getting a medium size mill.
I suggest brands like: Sherline, Homier, Rockwell/Delta, Clark, and a few others. With the lathes from Grizzly, and Harbor Freight, you will have to completely disassemble them and clean them up. As well as adjust all the slop. But you should know a good amount about lathes before disassembling.
Be careful, lathes weigh anywhere from 30lbs, up to 500lbs (for modeling to medium size, larger ones weigh 1000lbs up) and the shipping can be ungodly.
Also, a decent lathe 7x12 will set you back about $600+ and that doesnt include tools. Mills are around the same price, without tools.
-Mike
Old 01-02-2005, 03:10 AM
Dr.AK's Avatar
Dr.AK Dr.AK is offline
Could anyone tell me what a lathe or a mill is exactly? I know that they are used to produce parts made out of metal , but I've no idea how that works. Please, tell me. I'm curious.
Old 01-02-2005, 03:53 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Lathe : A machine for shaping a piece of material, such as wood or metal, by rotating it rapidly along its axis while pressing against a fixed cutting or abrading tool.
Milling:The act or employment of grinding or passing through a mill; the process of fulling; the process of making a raised or intented edge upon coin, etc.; the process of dressing surfaces of various shapes with rotary cutters.
Steve a.k.a. Hiroboy
Old 01-02-2005, 08:11 AM
Dr.AK's Avatar
Ah, thank you for clearing that up!
Old 01-03-2005, 08:37 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
I have a Sherline lathe and mill. They're perfect for modeling. The lathe turns terrific shocks and brakes (see my F50 thread for an example). A decent small lathe/mill combo will run you at least $500 - $700. Hard to justify for just car modeling, but home machining is truely another hobby into itself. I've been doing it about 5 years- I started when I scratch built an astronomical telescope. The Sherline setup was just big enough to machine telescope components, and it was a hell of alot of fun to build.
If you have any specific questions, I'd be happy to help you. Meanwhile, check out
www.sherline.com
It's enough to give you a good intro. Don't bother with larger machines unless you're going to have a use for larger machines- but decide what you're going to want do do before buying anything.
PHOTOBUCKET SUCKS
Old 01-03-2005, 08:53 AM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
I have a 7X10 lathe from Harbor Freight in the US. Its a Chinese design that is made by a number of Chinese companies and sold through a number of places like Harbor Freight, Micromark, etc. I chose this lathe because the bed is cast iron and looks much sturdier than the Sherline. There is a website and forum that can get you started from square one. Its called mini-lathe.com If you are interested in a lathe, I suggest you check it out. You'll find out what you're getting into. My whole setup cost about $700, and includes the lathe, some tooling, drill bits, and a bench grinder for making the cutting tools. I always have a blast making parts with it. I only got it for modeling, which makes it kind of expensive, but if I need it for making parts for other things, I have it. I also suggest you find a place to set it up permanently. I cant imagine having to move this thing around everytime you want to use it.
Old 01-04-2005, 08:08 AM
Eyeball Kid Eyeball Kid is offline
I've heard some rumblings about getting a CNC mill at work, then possibly a lathe later on. Please please please please please please please....
Old 01-04-2005, 07:11 PM
weaponCIVIC's Avatar
weaponCIVIC weaponCIVIC is offline
a small one like in the picture would be 500 bucks?
we have ones at my school that are bigger than me.....
http://www.automotiveforums.com/vbul...d.php?t=620111
"Look as far as the eye can see, go there, then look farther."
Old 01-04-2005, 09:08 PM
mike@af's Avatar
Re: Re: model lathes/milling machines
You're very lucky, those are thousands over dollars and thousands of pounds.
-Mike
Old 01-05-2005, 04:32 PM
I got no problem with the big parts if i need to ill got to my fathers gun shop he has alot of the big stuff i just want a small mill and lathe for the small parts so i dont have to go back and forth every time.
Old 01-06-2005, 09:05 AM
MPWR's Avatar
So you already have machining experience? What kinds of things are you wanting to make?
If all you need is smallish equipment, a Sherline lathe can be had for $483, and then another $139 for a vertical milling column will convert it into a perfectly adequate small mill. You'd still need a few excessories (end mills, collets, vise, etc.), but I doubt you'll find a less expensive set of tools. They're certaily more than enough for modelling applications.
PHOTOBUCKET SUCKS
Old 01-06-2005, 05:21 PM
i was thinking about makin some delrin slicks for cars and maybe attempting a aluminum block for my stang some simple small stuff for my cars. Im olny 16 so i dont have that much money but my dads going to get me one of the model lathes soon for my b-day i have made tons of control arms and stuff for my rc cars so i think im pretty good at this kind of small stuff.
