Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-04-2011, 12:13 AM
duder172 duder172 is offline
2006 Corolla - 2 flat tires in 2 weeks
2 weeks ago, one of my back tires suddenly went flat or popped and got torn up on the highway. I started to notice a louder than usual constant noise a few days before the first flat tire. After I replaced the tire, the noise continued when going 60mph+ and the car shook a lot at high speeds. Then today, the other back side tire went flat/popped as well. I got home with a spare.
Both were bought used, with probably 60-70% treads on still. Is it just crappy tires? Or is something wrong? Someone mentioned possibly bad wheel bearings?
This is my 3rd set of tires, 3 are the same brand, the one that just popped was different (a firestone), the one that popped 2 weeks ago was the same brand as the other 3. I forgot what the brand was.
It's a 2006 Toyota Corolla LE. All air in tire was at 31 PSI, as the sticker inside the door says. Mileage is 86,000...
It's front wheel drive. And the car doesn't make any *unusual* constant noises and does not shake at lower speeds, usually shakes a bit around 57+ and a lot around 65+. If that helps.
Old 02-05-2011, 08:34 PM
roadrunner2 roadrunner2 is offline
Re: 2006 Corolla - 2 flat tires in 2 weeks
Mixing tires: brand/size/tread design/used, etc is not always wise.
Most of the time used tires have been replaced for any number of reasons. Probably due to faults such as separations (which normally cannot be detected visually without technical assistance).
Perhaps there is a material fault with the rims. (Bent or cracked?)
The problem with doing nothing is not knowing when you're finished.
Old 02-07-2011, 09:19 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If it was a wheel bearing, then you'd definitely hear it growling back there and the car may even pull to that side. If it was a stuck brake, you'd feel it pulling as well and sluggish acceleration.
If it was a damaged rim, I would hope that the mech that replaced the first tire would have inspected it.
My guess is that something is contacting the inside tire wall and heating it up. Look at the inside wall and see if it has a shiny look to it. If so, that is where it is rubbing against something as it spins.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-09-2011, 05:34 AM
lexus1717 lexus1717 is offline
i guess there is some problem when fixing the wheel.Or just remeber that did you gone any where recently where the road is not good and full of sharp rocks.Just think a while and if not just try to change the service center and fix it again.
[link removed]
Bad wobble, 1999 corolla VE Dale_p Corolla/Matrix/Voltz 4 12-30-2009 10:57 AM
Flat tire sound, no flat tire monkeylizard Grand Prix 7 09-25-2006 08:22 AM
