Old 09-19-2006, 07:59 AM
monkeylizard monkeylizard is offline
Flat tire sound, no flat tire
It seems to be coming from the left rear and increases with speed. I'm mostly deaf in my left ear, so it could be the front. I tried to get my wife to listen too, but she wasn't much help. The only sound I can thing of is that it sounds like a flat tire, but not nearly as loud. There is no buzzing or squealing.
Any tips on what to check? I know I'm overdue on rotation, so I'm going to get to that this week.
2000 Pontiac GP GT
2000 Mazda 626 LX
Old 09-19-2006, 10:37 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: Flat tire sound, no flat tire
Is it a roaring or humming sound kinda like the sound mudgrip tires make on pavement? Could be your wheel hubs.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 09-19-2006, 01:30 PM
jem270's Avatar
jem270 jem270 is offline
When my rear hub bearing went bad on my 97 it sounded like a coffee percolator. I jacked up the right rear and the wheel moved like the lug nuts were loose but they were tight. I paid someone to replace it and it was pricey because of the anti-lock sensor was built into the hub.
Old 09-19-2006, 02:43 PM
Thorn71 Thorn71 is offline
jack it up and spin the wheel. there are tattle tails on your brake shoes to indicate that they are worn out. i believe that is what you are hearing
Old 09-20-2006, 12:37 PM
GPFred GPFred is offline
Could also be a busted tire belt. It too sounds like a flat tire. Sometimes you can feel it too depending how bad the belt is broken. You can check this by jacking up the car and spinning the tire. Look at the tread for a lifted spot across the width of the tread. You may even be able to see it from the side as the tire may look out of round. Running your hand along the tread will sometimes allow you to feel the change in tread height. Good Luck.
Old 09-20-2006, 12:58 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
IF you run your had around the tire in the direction of rotation and it feels smooth, then against the direction of rotation and you feel sharp points, then it's the overdue tire rotation that's causing your noise, as your tires are cupped. If they're smooth in both directions, then it could be a myriad of issues, including those mentioned above.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-20-2006, 09:45 PM
lilrogue78 lilrogue78 is offline
one more thing to check look beind the wheels to see if there is dirt bildup in your rims i have that problem alot because of all the dirt roads i drive on
Old 09-25-2006, 08:22 AM
Rotate and balance did the trick.
Now I feel dumb...
2000 Pontiac GP GT
2000 Mazda 626 LX
