Old 02-03-2011, 03:46 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
No wipers, A/C blower, power windows, no TC lockup, and ABS light on
Went to take my truck ('95 C2500) for it's annual emissions test the other day. I had replaced the battery beforehand because I left the underhood work light on and drained the old one DEADDEAD...could not be revived.
When I went to get in, the remote locks didn't work, nor the remote start (both are Viper brand aftermarket install). The truck started okay but I did not have any power windows, the A/C blower didn't run, no windshield wipers, and the ABS light was on. The power locks at the door worked. Concerning, but still driveable, so I went to get tested.
While driving, the brakes were fine but ABS did not work when I tested with a sudden stop. Also, the torque converter would not lock up at highway speeds.
I'm guessing a bad ground but don't know where to look for it...hints? Any other possibilities? Thanks for any help!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 02-03-2011, 05:56 PM
777stickman 777stickman is offline
Re: No wipers, A/C blower, power windows, no TC lockup, and ABS light on
Maybe some fuses blew on the batt change, so check those 1st. If it cranks and starts fine then most likely not a batt grounding issue. Try disconnecting the batt grnd for a couple of hours and see what happens. I don't have a '95 wiring schematic so I'm in the dark to help with what powers what.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-04-2011, 08:52 AM
Bob B Bob B is offline
Hi,
If your truck is like mine, (97 K1500) then there are two cables on the positive post that often don't make good contact. I had to remove the battery post bolt and really clean the wire ends. I also replaced the bolts with new ones from the auto parts store. While there I saw and bought a special small ratchet wrench for the little bolt heads, 6 sided 5/16 so I could tighten them better.
When it was failing, I could grab and move the cables to get it to work for a short time.
Bob B
Old 02-04-2011, 02:32 PM
jdmccright's Avatar
The RustBuster
I didn't check all the fuses, but I did check the wiper fuse when I noticed it not working and it was fine.
I did take a wire brush to the negative post bolt, but could stand to do the positive one, too, I suppose...yes, it has two cables. Doesn't make sense for some stuff to work and others not. I'll have some time tomorrow to look into it more.
Any and all help is appreciated...thanks!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 02-04-2011, 04:45 PM
With the ign sw in the "run" position check all fuses on both sides for 12v using a test lite.
So, this all happened with a simple batt change??
57 Chevy 210
Old 02-07-2011, 08:38 AM
jdmccright's Avatar
The RustBuster
Did the fuse block check with ignition on and got no power from the circuits affected. So I'm thinking it is a fusible link or the ignition switch itself.
If it is the ignition switch, can that be replaced while keeping the keys? I recall it being two separate yet connected parts, but would like confirmation.
I don't think it was the battery dying itself that caused this. My guess it was the attempts to recharge it with the battery charger that did it in.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 02-07-2011, 11:40 AM
j cAT j cAT is offline
the ignition switch is just that an electrical switch.
the key lock cylinder is linked to the electrical ignition switch..this is a separate part..common failure at this age the switch..
locate switch make sure connections are secure not burned up ..then replace switch.
Old 02-08-2011, 12:56 PM
jdmccright's Avatar
The RustBuster
Pretty expensinve for "just an electrical switch". But yes, it is old...16 years and 204k miles. Guess I can add this to my garage "to do" list. Thanks.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 02-09-2011, 03:01 PM
last time I got an ignition switch it was 30.oo ...not for your truck ..
how much for your vehicle ?
Old 02-18-2011, 01:44 PM
jdmccright's Avatar
The RustBuster
It's about $116 new at the parts stores...wouldn't trust a used part from a yard in this case. Hopefully, I can time it with a good coupon to bring it down $30-40. Thanks.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 02-18-2011, 04:52 PM
what I have seen is the springs break in the switch. contacts then do not wipe properly.
Old 04-11-2011, 06:37 PM
jdmccright's Avatar
The RustBuster
Got more time to dive into this and got to where the switch is loose but will not come out/off from where it connects just under the key lock. Any advice on how this comes off? I can pry it about 1/4" away before something springy keeps it from coming out...I don't want to pry too hard.
[EDIT] The key lock is still in the steering column, as is the upper column shroud, as some sites say you don't have to remove it and others say you do. I'd rather not fool with it if possible.
All I know is that it's the rainy season here in MD and having no wipers or ABS is bad....everything else not working is just a nuisance.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 04-19-2011, 12:40 AM
jdmccright's Avatar
The RustBuster
Turns out you need to remove the key lock because there are two screws that hold the switch in place and one is hidden by the upper column cover. Trying to move it out of the way isn't enough. To be continued....
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 05-06-2011, 11:04 AM
jdmccright's Avatar
The RustBuster
Got the new ignition switch installed a week or so ago and was not the problem. All the fuses look good, so it leads me to believe it is a fusible link. But I can't see them anywhere in the engine compartment. Are they covered up by the wiring harness sheath?
FWIW, I pried open the old ignition switch. The springs looked fine but the contacts did look oxidized. At least I only paid $45 for the new one.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 05-06-2011, 06:21 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
The fuse box gets power from battery threw a fuse link wire.
If it was bad you would not start or run or have power on any fuses.
First confirm good 12 volts to all fuses and also threw all fuses in fuse box.
Like check both sides of fuse for good voltage.
Maxie fuse no. 5 feeds ign switch for wiper and AC/heater and blower.
Make sure it has power on both sides at fuse box and is feeding power to ign switch and threw it.
Auto zone online used to have some wiring diagrams.
Maybe still do.
MT
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
2002 mountaineer rear power windows and wiper stops working juaniro Mountaineer 4 02-12-2010 07:22 AM
Power Windows Elec Prob. Please help!! dlane85 Corsica 1 07-29-2009 10:37 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
