Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-02-2011, 12:24 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Which trani line is return line? 87 Caprice
I've got a 700r4 and am wondering which trani line is the return line? The line connected to the upper or the lower part of radiator?
I picked up a trani cooler off a junkyard car and want to flush it out to avoid the possibility of contamination.
Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_1 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8B117 Safari/6531.22.7
Old 02-02-2011, 04:43 PM
Blue Bowtie's Avatar
Registered Offender
Re: Which trani line is return line? 87 Caprice
Typically, the line at the upper end of the radiator is the return to the transmission You should also verify that the lines at the transmission are connected correctly. The TH700-R4 is essentially the same as all other longitudal (rear drive) HydraMatic units except the TH200-4R.
For all longitudal units except the TH200-4R the lower oil port on the side of the transmission is the supply from the pump (flowing to the bottom of the radiator oil cooler). This includes the TH350 and 350C, TH375, TH200C, TH400, TH700-R4, 4L60/4L60E, 4L80E, and ST300/Jetaway. The TH200-4Rs are just the opposite.
2005 4t45e which is the return cooler line Ed_Strong Impala | Impala SS 5 03-10-2009 08:48 PM
2005 4t45e which is the return line Ed_Strong General Discussion 3 03-06-2009 09:16 PM
which is the return trans line from the radiator beermandtk Venture 1 05-27-2007 10:47 PM
Power Steering Fluid Lines... which is the Pressure line fitting on the rack? TheRev Avalon/Pronard 1 01-31-2005 07:03 AM
custom fuel return line or not????? jmsmathis Sephia 0 09-03-2003 07:57 PM
