Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 09-03-2003, 07:57 PM
jmsmathis jmsmathis is offline
custom fuel return line or not?????
i am working on a custom turbo application for my 2000 kia sephia but it has a returnless fuel system.this poses my biggest problem that i have found yet,i have narrowed it down to 2 options
1.custom return line
i will have to eather find a good mounting place on the fuel rail or drill a hole for the return line,then i will have to route the line back to the gas tank.
or
2.i have found out from my kia mechanic that inside the gas tank there is a stock fuel presure regulator connected to the fuel pump,this stock peice has a return line and another lie to the engine.my idea was to take off the the stock presure regulator and install a rising rate fuel presure regulator unit and also replace the pump with an upgraded unit as well.
my main question is would option #2 work even though the return line is not connected to the fuel rail???????
thanks
all you kia hatters come check out my sephia,and yes its has speed to go with it's looks.
http://pictures.sprintpcs.com/share.jsp?invite=mElr4Y5fzkhN68Yao8o8
www.streetkiaz.com
