Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 01-29-2005, 05:42 PM
TheRev TheRev is offline
Send a message via ICQ to TheRev Send a message via Yahoo to TheRev
Power Steering Fluid Lines... which is the Pressure line fitting on the rack?
'95 Toyota Avalon XLS New rack installed (almost) can't remember where which fluid lines tie into which rack fittings... non-pressurized and pressurized. My mechanic and good friend has a Haynes Manual but to no avail. He knows which lines are which but not where to fasten each one to the rack... there are no markings on the rack to indicate this. We are desperate. Thanks
Old 01-31-2005, 07:03 AM
tfeld tfeld is offline
Not sure if it's the same, but on my '01 here's the setup:
Inboard Control Valve Ports:
Lower/Forward = near Rack Housing
Upper/Rear = far Rack Housing
Outboard Control Valve Ports:
Lower/Forward = Pressure Feed Tube
Upper/Rear = Return Tube
Hope that helps.
