Go Back   Automotive Forums Car Chat > Automotive Art > Car Modeling > WIP - Muscle Car / Hot Rod
WIP - Muscle Car / Hot Rod Post topics for any "Works In Progress" Muscle Car-Hot Rod vehicles projects in this sub-forum.
Old 02-01-2011, 11:37 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
1970 Camaro Prototype Concept
Based on the 1st Generation Camaro platform, this is a styling exercise using what became the roof and rear end of the 2nd Generation Camaro.
The rear panel & roof/trunk is from an AMT ’70 Camaro, the main body is the Revell ‘69. The rear window frame was rescribed and sanded flush. The rear door lines were filled and new ones were scribed.
Old 02-01-2011, 12:52 PM
corvettekid_7684 corvettekid_7684 is offline
Re: 1970 Camaro Prototype Concept
WOW...another build I will be eager to see
Old 02-02-2011, 05:32 AM
countach79's Avatar
countach79 countach79 is offline
nice!
Old 02-05-2011, 09:39 AM
The rear bumper was too narrow, I don’t know if it is a problem with the AMT ’70 Camaro or something I did during the body modification since I did not test fit it until the body was re-worked, but it needed about 1/8th of an inch added.
BMF to re-plate it…
The rear corners of the body also had to be tweaked and built up to meet the bumper, the corners were a bit “soft”.
Old 02-05-2011, 11:10 AM
Hawk312 Hawk312 is offline
Cool idea. It looks like what might have been if they would have made a fastback `69 Camaro to compete with the Mustang.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 02-05-2011, 03:27 PM
The wheels from the AMT kit were the style I wanted to use, but needed some modifications to be used with the Revell tires, and they were not 100% correct, so thinned them out on the lathe…
And machined a set of beauty rings…
I was able to reuse the center caps after I cut some discs from aluminum to close off the open center portions of the wheels.
And some hex rod was sliced up for the lug nuts… Dark gunmetal with some silver accents and they are ready to install…
Old 02-05-2011, 06:10 PM
Man, have you got some talent...how did you get that BMF so smooth over the contours of that bumper? I'm still getting the hang of using that stuff...those wheels look perfect as well
Old 02-05-2011, 08:38 PM
Drift F.C's Avatar
Drift F.C Drift F.C is offline
This is awesome work!
or
Old 02-06-2011, 12:00 PM
Start in the middle and "massage" the BMF on to the part, it stretches pretty well. Toothpicks and Q-tips can help too; I just use my fingers and watch for wrinkles about to form. If they are about to form, just peel up the loose part of the foil to allow it to “flow” on to the part.
Silver was the only color in my mind for this car. Not a big fan of silver for body color, but it fits with the history of Chevy’s concept cars… Mica Silver with Pearl Clear…
Old 02-06-2011, 02:15 PM
klutz_100's Avatar
Super work all round - from the styling to the finish
Old 02-09-2011, 06:50 AM
HamburgerHead HamburgerHead is offline
great work so far! i love the way the two body styles have come together! how did you paint the lettering on the tyres and with what sort of paint? looking foward to the next update.
Old 02-09-2011, 11:52 AM
The tire lettering is the Scale-Master Art decals that came with the Revell kit.
I did a little wiring and plumbing last night. I was only going to add the ignition wires, but then I decided to add the bypass and heater lines, then a dip stick, a vacuum line, a temp sensor, fuel line, alternator bracket, throttle linkage... you know how it goes...
Old 02-09-2011, 12:33 PM
Looking good!! I'm curious about a couple items, like the vacuum advance canister, carb fuel line and dipstick, are they scratch built?
Old 02-09-2011, 01:37 PM
Thanks! The vacuum advance canister comes attached to the Revell '69 Camaro distributor in the kit. The fuel line and dipstick are scratch built.
Old 02-09-2011, 03:19 PM
The chassis is pretty much done on the bottom side. The bell housing has intentional overspray to replicate the way factory motors were assembled.
2009 Jetta Diesel in a 1970 Charger? Shpuker Classic Cars 2 07-27-2009 06:21 PM
** 2010 Chevy Camaro prototype photo - almost totally exposed! ** mlars Camaro Discussions 3 12-18-2007 08:29 PM
Ferrari Prototype Concept - AMV AMV Sketching and Drawing 9 07-02-2005 03:08 PM
*Completed 1970 Camaro*Outdoor Pics!* Sk8er6811 Completed Projects / Gallery 10 04-19-2004 02:36 PM
Check it out. 1970 Camaro, Twin Turbo, 650 HP Rodiron Camaro Discussions 4 01-16-2004 12:31 PM
