Old 01-31-2011, 09:20 PM
FRANKENCAMRY FRANKENCAMRY is offline
Starter Going?
My 2003 T&C 3.8L's starter seems like it starting to give out. Sometimes turn the key and nothing. Sometimes half a crank. Always if I turn key off then try again I get a strong crank and starts right up. Battery seems fine. Should I just go ahead and replace the starter? Or could this be something else?
Old 02-01-2011, 08:57 AM
jpb53 jpb53 is offline
Re: Starter Going?
There are a lot of reports of corrosion in the front control module. You could pull the relay and do some checks there. Wiring diagram here to help you with your testing.
Old 02-01-2011, 04:51 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Starter Going?
Two ways to determine (that I know of). Turn the key to start, listen for the click at the starter, then tap on it with a hammer. If it cranks, the solenoid contacts in the starter are shot. #2 (the best way) Turn the key to start. Using a meter check for 12vdc at the starter solenoid wire connection on the starter. It will be the smaller diameter wire of the two connections. If the voltage is there, again the solenoid contacts are shot.
You can change the starter or change the contacts for half the price but more work.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-01-2011, 05:20 PM
Scrapper Scrapper is offline
AF Premium User
Re: Starter Going?
did you make sure cables are good and clean and battery good charged? i'd try that then go for starter..
Old 03-23-2011, 06:27 AM
Re: Starter Going?
Getting ready to change the starter motor... (2003 - 3.8L) Appears simple. Haynes repair manual shows three bolts but I've read posts saying there's only two. Can anyone clarify? Is it easy to get out?
Old 03-29-2011, 05:42 PM
Re: Starter Going?
Just finished starter install. Haynes manual was wrong. There were two bolts and one guide pin. Upper bolt a bit of a PITA.
Also kind of hard to keep spacer in place when sliding in replacement motor.
Tip: use a small piece of tape.
94 Bonneville Starter Going? 94_Bonneville Bonneville 4 02-06-2008 02:52 PM
Possible starter going or false alarm? Vchat20 Windstar 6 01-27-2007 06:40 PM
starter going out? mikeferrell04 Problem Diagnosis 2 12-05-2006 09:13 PM
Think my starter going. Need Help. mentalcase Rodeo | Passport | MU 10 09-14-2006 10:41 AM
93 camry starter going bad hottmamita Camry/Camry Hybrid/Vista 6 05-14-2005 07:06 PM
