Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 01-28-2011, 12:17 PM
acidcrashdburnd's Avatar
acidcrashdburnd acidcrashdburnd is offline
Send a message via AIM to acidcrashdburnd
Exclamation Key stuck in ignition 2005 Cobalt LT
Hey My Girlfriends car has the issue where the key gets stuck in the ignition I read on here that you can pop a cover off under the steering column and pop the key out like you could do in the older W-Body GMs but I can't figure it out on this car. I have attached a picture of the steering column. Her car is sitting at work I have here going out every few hours to run it for 5-8 minutes to charge the battery back up.
sorry the pic is so big but i figured it would be best to not resize so you could see all detail.
Thanks for all your help..
1993 Olds 88 112k and counting 81 mile a day daily driver.
2005 Grand Prix 47k weekend car.
Old 02-05-2011, 04:04 PM
consultIII consultIII is offline
Re: Key stuck in ignition 2005 Cobalt LT
there should be a 1.5" square cover on the bottom of the column trim. Your picture is on the key side...look up from the floor. open the cover with a small flat screw driver. look for a white plastic "button" push it up with your index finger and hold. Remove the key. this works for dead battery conditons but not for bad key cylinders and interlock issues.
Old 02-05-2011, 04:14 PM
GTA's Avatar
GTA GTA is offline
Whee..
Common issue with a recall out there. The shifter assembly isn't recognizing it's in park so you can turn the key all the way to the off position. This has happened twice on my wifes 05 cobalt. Both times the dealer replace the whole shifter assembly.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
2005 Cobalt license tage light bulb? 2005cobaltdriver Cobalt 4 10-25-2010 10:11 PM
2002 Blazer Stalls, Key Stuck, Won't start MarkSpeed6 Problem Diagnosis 5 08-30-2010 02:14 PM
Key stuck in ignition--1999 6.8L v10 Too Many Old Cars Club Wagon 1 08-28-2010 07:56 PM
Key stuck ignition switch Crow Grand Prix 56 07-17-2006 09:58 AM
Key stuck ignition temp. fix jet black Grand Prix 0 08-11-2003 07:39 PM
