Go Back   Automotive Forums Car Chat > Chrysler > General Discussion
Old 01-27-2011, 11:44 AM
thomascathybell thomascathybell is offline
1996 T&C Instrument Cluster
My gauges, odometer, and all warning lights on the instrument cluser are dead. I am in the process of determining if the instrument cluster itself is bad. I am aware of the instrument cluster issues and have checked the soldered connections.
A question, if I may.
1) If the plug to the instrument cluster is connected with the CCD bus connections removed (pins 9 & 10 on the instrument cluster) should the odometer or any other warning lights light up?
I have checked the connections on the plug to the instrument cluster and there is voltage on B+ (pin 2) and Ingntion (pin 11). The ground (pin 7) is good. The panel lamp connections (voltage on pin 6 and ground on pin 13) are good and the panel lamps work. No other lights or the odometer light up. I have scanned for codes with a OBDII scanner and there are no codes.
1996 GJC Instrument Cluster Failure lkrewson Grand Cherokee | Grand Cherokee SRT8 1 03-16-2007 06:34 PM
99 T&C Instrument cluster problems- FYI nixonrules Caravan | Voyager 2 05-19-2006 02:59 PM
'99 T&C Instrument Cluster Circuit Board joedangerus Caravan | Voyager 0 07-13-2005 12:34 PM
'93 T&C Instrument Cluster has gone 'Black' Bob Reed Caravan | Voyager 2 09-27-2004 12:32 PM
'99 T&C instrument cluster problems! hybridmoment Caravan | Voyager 2 08-12-2004 05:15 PM
